Old 09-11-17, 04:59 PM   #11
SV650rules
Default Re: R & G heated grips for K3
I know a guy that does serious commuting on his Triumph, winter and summer, rain or shine. He had some muffs that he fitted, they stayed on the bars and he slid his hands into them, he swore by them.... Will try to find more info.
2016 SV650 AL7
Old 09-11-17, 10:58 PM   #12
phi-dan
phi-dan's Avatar
A friend gave me these as they were surplus to requirements https://rover.ebay.com/rover/0/0/0?m...2F182016987464
I found they were very effective, and even with summer gloves my hands were toasty without heated grips.
Sent from my Moto G (5) using Tapatalk
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan
Now: Blue FZ6 Fazer
phi-dan is offline   Reply With Quote
Old 10-11-17, 08:30 AM   #13
shiftin_gear98
shiftin_gear98's Avatar
Jane,
I have Oxford heated grips - used them for 7 years no issues. Two bikes mind. Current set have been fitted to my SV since I got it, as I couldn't bear not having them. (I get numb hands and the cold makes it even worse). 5 years ago - the grips are nearly worn through but as replacing the grips costs the same as a new set I will ignore the state of them until I have to replace it. (I'm skint).
I also have Halvarsson winter gloves. I find this combination fine for most of the ****e that winter throws at me on my daily commute. In the deepest darkest depths of last winter I have to admit the above wasn't cutting it anymore. I purchased something very similar to what phi-dan has linked. They are brilliant at keeping things toasty. Especially as I had the grips on and the gloves too.
I did however find them a pain in the ****. They are seriously clunky on the SV. I'm not sure if it's made worse due to my height 6'2" but the seemed to want to naturally point down when I needed them to point up.
Still when the weather gets ****e again they will be going back on, if I can remember where I put them. Which I can't as I type this....
Old 10-11-17, 08:33 AM   #14
shiftin_gear98
I actually have a horrible nagging feeling that I might have even binned them as they ****ed me off so much one day. Ah well, I'll find out when I want them.
Old 12-11-17, 06:57 PM   #15
shiftin_gear98
Found them!! Glad they survived.
Old 13-11-17, 12:04 PM   #16
Jayneflakes
Jayneflakes's Avatar
Good to hear.
I have been experimenting with gel hand warmers when out and that is helpful at the moment, but come winter I am going to need something warmer. Thanks for the advice folks, there is a lot here to think about.
Jayne you're a Pussy Magnet
Old 13-11-17, 01:51 PM   #17
R1ffR4ff
R1ffR4ff's Avatar
I've had a pair of Keis heated inner gloves for over 5 years.They are a tad expensive but quality.I always buy my winter gloves one size bigger than my hands to allow for inner-gloves.
https://www.google.co.uk/search?clie...CoHTkwXgiIKYCg
You do have to put the wiring in your jacket and have a socket to plug into on the bike.I have an SAE connector at the side of my bike which I also use for my battery tender.Also I used a bit of springy coiled wire from my jacket to the socket so when I get off the bike I don't accidentally rive the plug off etc.
I suffer from bad circulation/Industrial VWF(Raynauds) and these inner gloves keep my fingers just warm enough to fight this off but I also have some cheap Hand-Guards fitted.
I also take a 1-a-day Ginkgo Biloba tablet(Ebay) and these have helped with my circulation and fight against the cold.They can take about a month to realize their affect but they work for me.
HTH )
Old 13-11-17, 03:36 PM   #18
SV650rules
HTH )
I take Ginkgo tablets when playing Golf or walking outdoors in the winter, and they do help a lot with cold hands, you can get like thick gloves or mittens for golf but you get tired of keep taking them on and off and dropping them so I found Ginkgo does the job.
2016 SV650 AL7
Oxford heated grips vs. Keis Heated grips? MichaelM Bikes - Talk & Issues 41 21-11-13 12:40 PM
R&G heated grips dyzio For Sale - Other Bikes and General biking items 1 06-02-13 11:01 PM
Which heated grips? Springbokki Bikes - Talk & Issues 7 31-01-13 07:18 PM
Oxford heated grips and symtec heated grips Alpinestarhero Ancillaries 18 25-01-10 04:43 PM
Heated Grips NAPA121 Bikes - Talk & Issues 7 12-09-05 09:38 PM
