Old 22-04-13, 07:25 PM   #1
kiggles
Default can I tow a trailer?
i passed my car test in september and not sure if i can tow a trailer. I plan to do a track day some time this year maybe on my own bike.
found this?
https://www.gov.uk/towing-with-car/d...at-you-can-tow
but seen other people's licences who have the extra part on their licence. I have an old fiat punto mk1 and plan to find small trailer to pop the bike on. dobht its over 3500 kg?
Old 22-04-13, 07:28 PM   #2
Wideboy
Evel Knievel
Wideboy's Avatar
Default Re: can I tow a trailer?
yes you can. But you also need to check the towing limit of your car.
the 3500kg is the total weight of the car+trailer+load=cannot exceed 3500kg. This includes the weight of shiz you have in the car also. Basically, if you get tugged and asked to go to a weigh station and you exceed 3500kg your fecked.
05 DRZ400E
RIP hovis
Old 22-04-13, 08:07 PM   #3
cb1000rsteve
A punto and a bike trailer ain't gonna be any where near the 3500 limit. Never be tempted to ride to a track day (full day) After a full day on track you will be mentally tired plus if the worse happens your fooked.
Old 22-04-13, 08:29 PM   #4
kiggles
yeah I have heard its not wise to do so. hence thinking about a trailer. But planning on doing one of them schools before i take my bike down
Old 22-04-13, 08:34 PM   #5
cb1000rsteve
On ebay there is a bongotow. 251264700138 item no. Just carries the front wheel. Not sure if any good like
Old 22-04-13, 08:53 PM   #6
a_monkey_hint
I've towed a trailer a couple of times. A polo is less than 1000kg so you won't need to worry.
Two things about towing -
1) Give it more room when going around a bend - so you don't jump the curb.
2) Practice, practice & practice reversing - its not easy!
If you're going to have a bike on it you should be fine, but a friend once told me to use a trailer with a vertical post that you can see out the rear view mirror - best advice I've received as this helps in knowing where the trailer is when reversing.
Old 22-04-13, 09:21 PM   #7
Wideboy
Evel Knievel
Wideboy's Avatar
Not good. They'll square off your tyre and probably do some nasty **** to you chain and sprocket
05 DRZ400E
RIP hovis
Old 23-04-13, 05:17 AM   #8
L3nny
L3nny's Avatar
Default Re: Re: can I tow a trailer?
Loads of people ride to track days, I've done about 10 and never fallen asleep on the ride home only reason you need a trailer is if you're fitting non road legal tyres.
2015 GS 1200 Adventure
Trailer or van help Littlepeahead Soho Massive 4 22-06-12 08:39 PM
Trailer Kilted Ginger SV Ecosse 3 05-06-12 09:36 AM
Can I tow a trailer or not?! Paul the 6th Idle Banter 14 24-11-11 10:59 AM
car trailer fenjer SV Ecosse 1 22-04-11 03:18 PM
Trailer to bike trailer conversion ? stewie Bikes - Talk & Issues 14 10-12-09 12:20 PM
