16-10-08, 07:05 PM | #1 |
gsxr front fork springs, rider weight
hi all,
after getting the gsxr1000 k2 front end on and everything settled down i have started to play with the settings as the ride was a bit 'firm' to say the least. the settings at the moment are: compression - all the way down '1st click' rebound - all the way down then 4 clicks up spring compression - all the way up (softest) with above settings the compression is still rising on bumps but the rebound is just about right but i still get a bit of 'pogoing'. the fork travel goes no where near the bottom of the fork tubes (lucky if its 2/3rds down under heavy breaking) i'm 10-10.5 stone and i feel its still a bit firm. so the question is do you think i need a softer set of springs? i mainly ride on bumpy B roads. i have looked at the racetech website and used there calculator and it says that the stock springs are about right for my weight. as yet i have not changed the oil or checked the springs but it looks as though someone has been into the forks already (telltail spannering on caps) they also came with ohlins stickers on the bottom of the forks, so i have no idea if the springs have been changed. |
16-10-08, 07:34 PM | #2 |
Re: gsxr front fork springs, rider weight
You have the damping all the way up!! ... no wonder it feels 'stiff'
16-10-08, 07:42 PM | #3 |
16-10-08, 07:44 PM | #4 | |
Eh?? .... compression - all the way down '1st click' rebound - all the way down then 4 clicks up To me that is saying you have wound them all the way in, then 1&4 clicks out?!!? That is essentially pretty much the highest/stiffest (slowest moving) setting you can have ...give or take a click or two |
16-10-08, 07:48 PM | #5 |
ok, i'm bad at explaining things.
what i should have said is compression setting is all the way out to softest position rebound is 4 clicks from softest position spring is at its softest position... does that help? |
16-10-08, 08:00 PM | #6 | |
Just to confirm ... are you thinking fully clockwise is softest, or fully anti-clockwise? |
16-10-08, 08:32 PM | #7 |
compression all the way round anti-clockwise
rebound all the way round anti-clockwise then 4 clicks clockwise spring pre-load all the way round anti-clockwise to number 5 groove |
16-10-08, 08:35 PM | #8 | |
In which case, YES its looking like they have been re-sprung and you either need to eat more pie, or re-spring ... Getting some 2nd hand stock springs (should be cheap as chips mind!) If you can establish their 'weight' you can prolly sell the ohlins for a tidy profit |
16-10-08, 08:47 PM | #9 |
cool, cheers blue
i'm trying the pie solution at the moment, but thing is the more i eat the more it comes out the other end i don't have the means to establish the weight of the springs so they will prob end up in a dark place somewhere in the back of a cupboard. unless some org'r wants them. so now to find some springs... |
16-10-08, 08:58 PM | #10 | |
2nd hand stock springs will go for pence ... it is not actually that hard to work out teh 'weight' of the springs ... you just need some dumbbells and a ruler |
Ohlin front fork springs | Mike2165 | Stuff Wanted | 5 | 08-10-07 12:14 PM |
Front Fork springs | stev | SV Ecosse | 7 | 30-04-06 10:29 PM |
front fork springs | mata15 | Ancillaries | 1 | 13-11-05 02:25 PM |
Front fork springs | falc | SV Talk, Tuning & Tweaking | 14 | 15-07-05 02:13 PM |
Will SK1 front fork springs fit a curvy? | streetos | SV Talk, Tuning & Tweaking | 3 | 17-06-05 02:48 PM |
