Over the year and =half ive had my bike, ive come across a number of problems which will make your bike run like crap.
When your bike is running like crap check the following:- Little nipple which goes over the vacume nipple on the front carb where you put the vacume guages onto - Becomes perrished and starts sucking in air, causing popping and running problems, Side Stand spring becomes loose and strethced over the years and causes the side stand to flop down and cuts your bike out because the switch is not getting pushed in by the stand because it is loose. Bike running on one cylinder - Could be because the front plug is wet, but what i found out was the HT coil for the front cyclinder had green corrosion on the terminals making it not work. Just thought id share my problems with you and solutions with you. |
Thanks Hooligan, I'll check those on my bike this weekend as part of my planned TLC session
Me too!!!!!
Oil light solutions (curvy 99) | vardypeeps | SV Talk, Tuning & Tweaking | 7 | 14-04-09 08:39 AM |
Curvy cam chain tensioner noise, solutions? | Lugusto | SV Talk, Tuning & Tweaking | 12 | 12-04-09 01:48 AM |
running problems maybe? | kwak zzr | SV Talk, Tuning & Tweaking | 14 | 16-06-07 10:47 PM |
Running problems | watto | SV Talk, Tuning & Tweaking | 4 | 10-11-06 11:54 AM |
Running Problems | Claire | SV Talk, Tuning & Tweaking | 6 | 12-12-05 09:05 AM |
