Old 21-01-16, 08:36 AM   #1
tom_e
Default Bar end fitting
It looks like the previous owner made a right mess of the bar ends on my SK5, the bit inside the clip on that the bolt bites into seems to be a bit mashed up so getting new ones bolted in tight doesn't seem to be happening.
Whatever the bolt screws into seems to be spinning in the clip on so I can't unbolt it or tighten it.
Any ideas?
If I can at least get the bolt out and there's enough space in the clip on before the rubber I'm just going to stick some universal ends on, which is a shame because my brand new R&G one's are so shiny.
tom_e is offline   Reply With Quote
Old 21-01-16, 08:47 AM   #2
Default Re: Bar end fitting
Pull the rubber inside out and have a look. It works on friction so may be pushed in.
Replacement bolts, go to an engineering factors with it and they should be able to get a match
Sent from my E2303 using Tapatalk
Old 21-01-16, 08:49 AM   #3
tom_e
so the rubber that the bar ends screw into is just held by friction? If that's the case I'll get some wd40 down it and give it a good yank
Sent from my XT1092 using Tapatalk
Old 21-01-16, 11:07 AM   #4
tom_e
After some Googling it looks like you're supposed to be able to pull the rubber and the bar end out as one once you've slacked the bolt slightly, this was never going to happen with the bar ends that were on there they appeared to just be screwed into the rubber bung.
So now I imagine the nut the bar end bolt is supposed to screw into is just flapping around at the other end of my clip on and that's why I've got nothing to screw the new ones into.
What's the best way of pulling the old rubber out? It doesn't look like you can take the other end of the clip on off and push it out.
Old 21-01-16, 11:29 AM   #5
Crawling Finn
I have used bicycle spoke successfully before.
Crawling Finn is offline   Reply With Quote
Old 21-01-16, 10:43 PM   #6
tom_e
Went for the delicate approach in the end, got a socket extender and a rubber mallet and just bashed the rubber bungs far enough down the clip ons that I can fit a set of Oberon universal bar ends on now.
Need help fitting a top box adamw2k2 SV Talk, Tuning & Tweaking 20 12-08-09 08:09 AM
Fitting kit kashby Stuff Wanted 1 15-01-08 02:03 AM
FITTING KIT?? benyboy Bodywork 4 22-01-07 01:42 PM
Help fitting my new can.. 5v5 rider SV Talk, Tuning & Tweaking 17 03-07-06 08:16 PM
HELP... Fitting R&G's WelshWop SV Talk, Tuning & Tweaking 6 29-05-05 11:09 AM
