Old 19-03-17, 09:31 AM   #1
Stilo
Stilo's Avatar
Default Fork Bush
The fork bush/bush guide. i.e the split bush that is teflon coated on the inside.
The Suzuki manual says to insert it, the Haynes says insert it is as far as possible.
I have used a length of plastic pipe as a drift but it is not fully flat/fully inserted, it is slightly proud.
I dont want to try & use a metal drift in case I damage the chrome on the stanchion.
Does it have to be fully inserted and if so any advice on how to do so or will "as far as possible. " be OK?
Thanks
He was a hairy handed Gent who ran amok in Kent Awhooo
Stilo is offline   Reply With Quote
Old 19-03-17, 12:38 PM   #2
R1ffR4ff
R1ffR4ff's Avatar
Default Re: Fork Bush
I've not done any work on SV forks yet but there's some YT videos that may help,
https://www.youtube.com/results?sear...0+fork+rebuild
Old 19-03-17, 01:48 PM   #3
garynortheast
garynortheast's Avatar
There's a large washer that goes over the top of the bush and under the seal. I put that over the bush and then used a copper drift to gently tap the washer and drive the bush home. Take your time, repeated small taps rather then several hefty clouts will win the day!
Old 19-03-17, 09:07 PM   #4
Dave-the-rave
Dave-the-rave's Avatar
The bush shouldn't be proud enough that the washer can't sit flat on it's ledge.
SV650N K1
Dave-the-rave is offline   Reply With Quote
Perfect suspension fork bush and seal fitting tool. beabert SV Talk, Tuning & Tweaking 6 31-05-13 03:01 PM
front fork bush question DaveW_42 SV Talk, Tuning & Tweaking 3 13-09-09 06:26 PM
Fork seals and bush prices - WT*? sam anon SV Talk, Tuning & Tweaking 5 30-01-09 02:22 PM
swing arm bush colinsv25 SV Talk, Tuning & Tweaking 10 27-11-07 04:56 PM
bush gag...could be old keithd Idle Banter 10 10-02-06 07:00 PM
