30-12-07, 02:16 AM | #1 |
First Gear Not Fully Disengaging
Hi All,
This is my first post as I can't find another thread regarding this particular problem. The problem is that when in first gear and clutch fully engaged, my SV still tries to lurch forward. I can hold it back with not much effort with my feet on the ground... I don't need to use brakes or anything. No problems in second, third or any other gear... only first. I've tried adjusting the clutch cable tension many different ways and now have it set to give me the smallest chance of a runaway bike. I realize that there will always be a little wheel movement with the clutch in , but not to extent that you can feel it pulling. Has anyone come across anything like this before? Any help would be much appreciated. Thanks |
30-12-07, 03:35 AM | #2 |
Re: First Gear Not Fully Disengaging
before you adjust cable you have to adjust mechanism that pushes clutch.
if that is not problem than you might want to take look at clutch. |
30-12-07, 04:17 AM | #3 |
Does this happen everytime, or do you only notice it if the bike has been standing when you first put it into 1st gear?
My old xj600 diversion used to lurch when I first put it into 1st gear in the morning after it had stood all night. As far as i could tell the clutch would develop a sort of stiction overnight and even though I had pulled the clutch lever in the plates remained stuck together. When i selected first gear it would lurch slightly and the clutch would come unstuck and it was fine after that (well untill it had been left standing overnight) |
30-12-07, 11:10 AM | #4 |
It sounds like the clutch is not fully disengaging. If you are struggling to resolve the problem I live in Penicuik if you want to pop out for me to have a look at it for you. Send a PM.
30-12-07, 12:20 PM | #5 |
If this is the only problem you are experiencing with the clutch, it sounds like the clutch is not fully disengaging (as 'lookskyward1' said)! Check the mechanism by the front sprocket as well as the adjuster on the lever, you will need to adjust it by the front sprocket if you are running out of adjustment at the lever.
30-12-07, 03:20 PM | #6 |
hey guys,
thanks for your comments. a friend of mine (who knows a bit about bikes) has played around with the adjustment on the sprocket. I'm not if we did it right but tried various differnt settings. The problem occurs all the time, yet is more noticable sometimes than others. There is a bit of a burning smell coming from the engine when stopped at junctions etc... although that might be related to another problem I have (seized choke which i hope to get around to sorting in the new year or crud flyin up onto the engine from the filthy, wet roads). As my other problems seemed to be common with SV's, I thought maybe this one was too. If i take off the sprocket cover, is there anything obvious to look for that might cause a problem like this? Thanks again. ps. lookskyward1.. thanks for you offer. very generous. hopefully i will be able to sort this out myself but i will send you a message if i have no joy. cheers |
30-12-07, 05:02 PM | #7 |
Check to see how much cr*p is behind the sprocket cover, give it a good clean out and you might see something causing a problem but I doubt it.
How do you mean seized choke, is it stuck open/closed??? |
30-12-07, 05:13 PM | #8 |
If the choke is seized on giving you a higher than 'normal' idle speed this may make the matter worse and both problems together may contribute to the burnt smell.
If the sticking clutch still persists once you have eliminated the clutch cable adjustment/crud in the sproket area, it may be worth opening up the clutch to check to make sure the multi plates are not sticking in the basket and not damaged/warped from overheating. An engine oil and filter change will probably be worth it as well if the clutch has been cooking. |
30-12-07, 09:44 PM | #9 |
hey,
ive changed oil and filter about 3 weeks ago. thought that might have helped but it didnt. funny thing about the choke and idle speed actually. the choke is open on one cylinder i think. i turned idle speed up as clutch only grips at low revs. it seems the engine speed reaches a point where the friction is broken between the plates... does that make sense? dont know how to explain this properly. like how a coin will slide easily across a table but the initial force needed to move it from stationary is greater. would you be able to smell a burning smell from the clutch plate overheating due to excessive friction? |
30-12-07, 11:48 PM | #10 |
know all about the crap behind the sprocket cover, Im Indoors had suze one winter going with only 2nd and 4th, 5th gear. or depending how it felt would give you first gear occasionally. We now know to check the gear shift shaft for crap on a regular basis
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
Gear Shift Rod bent - Gear Changing problem | Thaleshwar | SV Talk, Tuning & Tweaking | 13 | 05-06-10 06:28 PM |
Clutch not disengaging | Jamie_SV | SV Talk, Tuning & Tweaking | 5 | 04-04-09 06:57 PM |
Clutch Not Fully Disengaging | mosius | SV Talk, Tuning & Tweaking | 1 | 25-08-07 06:24 AM |
Check fully after an off | timwilky | Bikes - Talk & Issues | 28 | 22-05-07 07:09 PM |
Clutch not disengaging. | Mesomorphman | SV Talk, Tuning & Tweaking | 22 | 19-09-06 09:40 PM |
