20-11-05, 03:13 PM | #1 |
snapped engine case bolt
just installed my pro bolt alloy engine case kit and on the very last bolt i snapped the head off
whats the best way to remove the bit ot the bolt thats left in? its broke about 5mm under the head of the bolt if that helps Thanks alot |
20-11-05, 03:14 PM | #2 |
Nice. I dont know quite how you'd get to that, the only thing I could suggest is a drill!
20-11-05, 03:16 PM | #3 |
If you take the casing off again, how much stud is left? Enough to grab with a proper extractor?
20-11-05, 03:28 PM | #4 |
is it ok to just remove all the case?
sorry to sound dumb but im new to this bike stuff |
20-11-05, 03:33 PM | #5 |
Which side is it?
I don't see that you have a choice in the matter, it's just a matter of how much oil is going to come out and make sure you put it back in after you've put the case back on. |
20-11-05, 03:59 PM | #6 |
Do not Drill it remove the casing and hopefully you will be able to undo it easily as it will not have seized in tight the thread should still be lose. Always use a torque wrench when fitting these type of bolts
20-11-05, 04:02 PM | #7 |
so i may as well do an oil change while im on the job?
its the nearside? |
20-11-05, 04:24 PM | #8 |
If you remove the case you should be able to get at the remainder of the stud, try removing this ( if it doesnt move with hand pressure try mole grips )
Drilling it should be the last resort ( but you should be ok as long as it was the head of the hex/cap head shearing off against the case, not the bolt bottoming out in the hole ) |
20-11-05, 04:50 PM | #9 |
will i need a new gasket?? if i remove the engine case?
20-11-05, 05:29 PM | #10 |
If you cant get at with mole grips, then you will need to drill it and remove it with eazyouts.
Snapped lower yoke bolt. | DavieSV | SV Talk, Tuning & Tweaking | 10 | 18-05-09 09:10 AM |
Farrrk Snapped Exhaust Header Stud Bolt | 21QUEST | SV Talk, Tuning & Tweaking | 25 | 02-08-08 09:40 PM |
Snapped Radiator Bolt. | TheShadow | SV Talk, Tuning & Tweaking | 6 | 06-04-08 12:56 AM |
99 sv650s - Snapped a bolt | dhtmldude | SV Talk, Tuning & Tweaking | 1 | 05-03-08 10:41 PM |
snapped a disc bolt! | haggis | SV Talk, Tuning & Tweaking | 4 | 31-03-07 07:32 PM |
