Old 20-12-21, 12:36 PM   #2571
gt alex
Default Re: What have you tinkered with today?
https://scontent.fbne3-1.fna.fbcdn.n...zg&oe=61C5572D
gt alex is offline   Reply With Quote
Old 20-12-21, 01:33 PM   #2572
Craig380
That's very cool.
Old 20-12-21, 03:04 PM   #2573
very cool indeed
Old 21-12-21, 01:10 AM   #2574
svenrico
svenrico's Avatar
Bibio , thanks for that info , will give it a go.
svenrico is offline   Reply With Quote
Old 25-12-21, 05:24 PM   #2575
DJ123
DJ123's Avatar
Between yesterday & today;
Replaced headlight Bulb & rear brake pads
Also washed/cleaned all my Kit too. Ready for riding again in the New Year.
BMW F800ST
Old 31-12-21, 03:24 PM   #2576
CheGuevara
Installed Xmas bling. I still need to do the wiring for both levers, but want to get some OE-style connectors.
Motul RBF600 at approx 18months (in the glass) vs fresh (in the reservoir). That's very few road miles and a couple of track days (slow group).
- K9 SV650S: Hel brake lines, carbon end can
- SZR660: The project...
- K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now)
CheGuevara is offline   Reply With Quote
Old 08-01-22, 01:10 PM   #2577
DJ123
DJ123's Avatar
New Stator fitted to the bike. Seeing as its had its electrical gremlins the past year, it's the only part not yet replaced (although always tested as good).
With it being winter/crappy weather it's the best time to strip it down and get it done.
BMW F800ST
Old 08-01-22, 02:06 PM   #2578
SV650rules
A 'series' type R/R will give the new stator an easier life, instead of demanding full power from the stator all the time and shunting unwanted power to earth ( hence the name 'shunt' which is electric speak for 'parallel' ). The series ( electric speak for 'in the same line as' ) only takes from stator what is needed, like a light dimmer would. Just fitting an electrex series RR to my AL7 to replace the mosfet OEM Shindingen one reduced heatsink temp from 75 degC to about 40degC, (temp from temperature probe on same day at same ambient temp). It would have reduced stator winding temperature as well, although I had no way of measuring that easily. The electrex unit also rock solid on output voltage across rev range ( I have a digital meter on the handlebars ) between 14.3 and 14.4 volts - as Sid Larkin would say 'Perfick'
2016 SV650 AL7
Old 08-01-22, 02:30 PM   #2579
DJ123
DJ123's Avatar
That's my next purchase, when/if this RR goes and the one i have on the shelf too. Hopefully my
BMW F800ST
Old 16-01-22, 08:20 PM   #2580
DJ123
DJ123's Avatar
No tinkering as such today, but a test ride after the new Stator was fitted.
So far the good news is the voltage appears to be stable and the bike running well. Although it wasn't a long ride today (didn't want to venture too far, just in case) it was a successful first test. The next ride will be longer with some more electrical draw, to test if it is still able to hold a continuous output.
BMW F800ST
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
