View Poll Results: Check valve clearances at 32K miles when they were fine at 15K?
Yes, check them, you lazy get 2 33.33%
Nah, they were fine at 15K, they're unlikely to have changed since 4 66.67%
Voters: 6. You may not vote on this poll
Old 23-12-21, 03:21 PM   #1
Craig380
Default Gen 3 valve clearance checking after 32K miles
Bike is just over 32K miles. I checked the clearances at 15K miles and all were within spec: all inlets at either 5 or 6 thou, and all exhausts at either 8 or 9 thou.
So would you:
A) Check the clearances again while the weather's crap?
B) Leave it on the basis that they were fine at the first check, and are unlikely to have changed, given that the bike gets oil & filter changes by the book and very rarely sees more than 8,000rpm on the clocks?
Old 23-12-21, 03:35 PM   #2
garynortheast
garynortheast's Avatar
Default Re: Gen 3 valve clearance checking after 32K miles
Mmm, probably the last person in the world who should be offering a view but I've made it to nearly 102,000 miles and never looked at the valve clearances.
Old 23-12-21, 03:53 PM   #3
DJ123
DJ123's Avatar
i really wouldn't bother. Unless you are someone who is regularly and consistently riding the bike in the upper end of the rev range, they should be fine. Unless there are running issues making you think there's an issue, i'd leave them be.
BMW F800ST
Old 23-12-21, 04:19 PM   #4
Craig380
I was going to add a note saying "Gary, I know which way you're going to vote" but I didn't want to prejudice the outcome
Old 23-12-21, 06:52 PM   #5
garynortheast
Old 24-12-21, 12:50 AM   #6
Ruffy
Ruffy's Avatar
Unless you really need the peace of mind, I'm in the 'lazy and trusting that they're unlikely to have significantly worn' camp.*
IMHO, as you suggest, keeping enough fresh oil for good lubrication is the best medicine. (Checking cam chain tension is the next consideration but you'd probably hear quite clearly if that was badly out.) SV motors seem to have good oil distribution systems - we're not dealing with an early Honda VF here, thankfully!
Of course it's anecdotal but I've only sporadically checked valve clearances on many cars and bikes I've had over the years. Never found a serious issue to do with valve clearances and I've run to some quite high mileages too. Like you, I am generally a 'lighter' user of the throttle but I'm not afraid to go close to the red line on some occasions.
* No liability accepted if you follow my approach!
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue.
RIP SV650 X curvy, crashed and written off December 2019.
I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road.
Ruffy is offline   Reply With Quote
Old 24-12-21, 08:11 AM   #7
Seeker
Seeker's Avatar
I'm in the 3rd (not listed) option - too lazy to do it myself but anxious enough that I'd pay someone else to do it.*
If I didn't get them checked I'd be fretting about them on every ride. "What's that noise?" or "Why is the engine so quiet?"
I'd prefer to be in: "they'll be fine, what could possibly go wrong?" camp.
*(Mine were checked at 29k by the dealer - all were in spec.)
2016 SV650AL7
2023 GSX-8S
Old 24-12-21, 08:26 AM   #8
they will be fine. but for what it costs to get a dealer to do it or even down time for yourself its worth checking. from history on this and other SV sites the consensus is that the first check is good enough. i have never heard of an SV blowing up, dropping a valve or burning seats out due to valve clearances.
SV650 valve clearance checking? stranger12 SV Talk, Tuning & Tweaking 7 19-12-13 10:12 AM
Valve clearance checking questions. Terah SV Talk, Tuning & Tweaking 12 12-03-11 07:20 PM
Valve clearance, should I take it? Old Git SV Talk, Tuning & Tweaking 21 14-09-09 11:54 AM
Valve clearance checking. Mark_h SV Talk, Tuning & Tweaking 6 22-12-08 08:31 AM
Valve Clearance Craig SV Talk, Tuning & Tweaking 3 14-02-05 07:34 PM
