27-10-07, 03:08 AM | #1 |
Bent rim!
Managed to hit a big lump of wood at a not inconciderable speed the other day and I've managed to dent my rim.
It doesn't look too bad (bout 3" long, worst bit pushed in about 1-1.5cm). Just wanted to know if this was repairable or if it's not a good idea to repair a rim. If it is repairable, how would I go about fixing it or where woud I take it?? Regards
Phil I'm not here for a long time, I'm here for a good time! Blue SV650 K3, GSX-R K5 front end, TL1000S clip-ons, lower fairings, seat cowl, gel seat, Pyramid undertray, R&G crash bungs, stainless steel bar ends, full titanium Akrapovic exhaust, Power Commander, clear rear light, flush mount front indys, mini rear indys, Autocom 300 duo intercom, Acumen cat 1 alarm and Micheline Pilot Power 2ct's. |
27-10-07, 06:54 AM | #2 |
Re: Bent rim!
It is possible for wheel rims to be repaired. Do a google search, there are hundreds of places that can do it.
It obviously depends if it is just the rim of the wheel that is damaged and by how much. The experts should let you know when you call. |
27-10-07, 08:13 AM | #3 |
Re: Bent rim!
I've used these guys before:
http://www.motoliner.com/alloy_wheel_repair.htm Quite speedy turn around. One of the wheels I've had done by them had similar damage to what you're describing. HTH.
http://ridingalongwayslowly.blogspot.co.uk/ 3x Honda C110 - phut-phut-phut KTM Duke 690 - brum-braaaaaaa!!!!! BSA C25 - brum-braa-braa RD350LC Ring-ding-phut-clatter-££££££ Last edited by RingDing; 27-10-07 at 08:14 AM. Reason: Correcting one handed typing mistakes! |
27-10-07, 09:25 AM | #4 |
Re: Bent rim!
i was just going to say motoliner if you can stand the postage too and from there premises they are about the best place.
27-10-07, 12:38 PM | #5 |
Re: Bent rim!
Cheers guys I will look into it!
Regards Phil
27-10-07, 01:38 PM | #6 |
Re: Bent rim!
i wouldn't repair it the wheel is weakened bending it back wont improve it any just make it weaker
how much is your life worth |
27-10-07, 01:44 PM | #7 |
Re: Bent rim!
Bout 50p!
27-10-07, 01:53 PM | #8 |
The Sick Man
Re: Bent rim!
If this was the case i think that places that straighten wheels would be sued left right center. Everyone does it.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
27-10-07, 02:16 PM | #9 |
Re: Bent rim!
27-10-07, 02:16 PM | #10 |
Re: Bent rim!
Bent exhaust | lukewalton | SV Talk, Tuning & Tweaking | 5 | 04-01-08 02:04 PM |
Bent exhaust | lukewalton | SV Talk, Tuning & Tweaking | 0 | 04-01-08 01:39 AM |
Bent fairing | Bayside GTR | SV Talk, Tuning & Tweaking | 6 | 01-11-07 12:25 PM |
Bent Subframe | Torn-Thorax | SV Talk, Tuning & Tweaking | 6 | 05-03-07 06:53 AM |
Bent Forks... how much is too much? | WhiteRabbit | SV Talk, Tuning & Tweaking | 1 | 13-11-04 01:09 AM |
