01-04-17, 12:17 PM | #11 |
Re: Electrical help needed
[QUOTE=Red ones;3066853]There should be a white connector for the front lights to the wiring loom. Any idea where it hides before I tackle the fairing removal fiasco?
Left hand/clutch side of the headstock
He was a hairy handed Gent who ran amok in Kent Awhooo |
01-04-17, 02:21 PM | #12 |
Suzuki mechanic smiled when I saw him just now. Go for the switch gear and connector block remove corrosion and spray with ACF50.
01-04-17, 03:10 PM | #13 |
01-04-17, 04:29 PM | #14 |
Sounds good, there's nothing wrong with those voltages at the battery.
01-04-17, 04:32 PM | #15 |
DO you have any more details on that mod, for example the parts used etc?
01-04-17, 05:25 PM | #16 |
Well.
I looked for the big connector under the air box but couldn't find it, so I'm not sure it's actually on the Sk8. I pulled all the connectors to the lights I could find except one that is clearly behind the console but it can't work out how to get to. I pulled all the lighting fuses and put them back in. I stripped the switch gear on the handle bars on both sides. All connectors checked for corrosion and then sprayed with ACF50 While I was at it I also changed the oil filter. Lights still dim with the indicators but not as much as before. I couldn't see any flickering at tick over. |
01-04-17, 07:22 PM | #17 |
06-04-17, 12:03 PM | #18 |
Had anyone got any advice on the mythical main electrical connector on the LHS under the airbox? I can't find anything that looks suitable are that I can break in to.
Is it this bit just inside the frame? |
06-04-17, 12:29 PM | #19 |
You wish it was that easy to get to! It's more behind the steering stem. Prepare for skinned knuckles
06-04-17, 04:19 PM | #20 |
Nope. Can't see it.
It has to be that connector that's the problem too. The dash dims in time with the revs, but the charging system and battery are all spot on. I just need to sort the connector out!! |
Electrical help needed. | funkydruid | SV Talk, Tuning & Tweaking | 1 | 14-11-15 06:13 AM |
Electrical Genius Needed | pben47 | SV Talk, Tuning & Tweaking | 13 | 01-02-08 12:36 AM |
Help needed - Electrical Fault | richard_1069 | SV Talk, Tuning & Tweaking | 8 | 14-06-07 08:14 PM |
Electrical troubleshooting help needed | northwind | SV Talk, Tuning & Tweaking | 11 | 10-02-07 10:19 PM |
Meta alarm and electrical help needed | jakeblues68 | SV Talk, Tuning & Tweaking | 2 | 12-09-05 09:57 PM |
