13-04-17, 11:02 AM | #11 |
Re: Milky fluids
Im hoping so but it doesnt take long to check the freeze plugs around the cams. Its part of the procedure. I emptied the coolant and refilled with the oil drain plug in so if i go back and a whole load of water comes out then it 'may' point to the water pump as the issue.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ), drop it & fix it again! K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
Guy makes mistake tasting bike's fluids | L3nny | Idle Banter | 7 | 25-03-15 07:02 PM |
Coolant fluids - what & where to get them. | muzikill | SV Talk, Tuning & Tweaking | 1 | 03-05-11 10:45 AM |
Suzuki sv 650 greases & fluids equivalent list | muzikill | SV Talk, Tuning & Tweaking | 19 | 07-03-11 09:32 PM |
The Milky Way | DarrenSV650S | Idle Banter | 1 | 15-06-09 11:50 AM |
Brake fluids .... More useless information | Spokey | SV Talk, Tuning & Tweaking | 21 | 03-11-08 09:36 AM |
