Old 15-02-07, 10:43 AM   #1
ejohnh
Default How do you measure that thing called sag?
I have tried searching for this with no luck.
My K1 skips over bumps when cornering at fairly low speed. Front seems to have a mind of its own! I've been reading the threads about changing springs and oil and stuff, and they also talk about measuring 'sag'. What is sag and how do you measure it?
John
Old 15-02-07, 10:54 AM   #2
timwilky
timwilky's Avatar
sag, is how low on the suspension the bike & rider sits. To my way of thinking it should be about 1/3rd of the available travel.
Not Grumpy, opinionated.
Old 15-02-07, 03:39 PM   #3
petevtwin650
My 2001 curvy has about 110 mm of fork travel and the books say to start with around 20 - 30 mm of sag with the rider sat on the bike, feet on pegs.
Old 15-02-07, 05:31 PM   #4
ejohnh
So is the procedure:
1. sit on bike with feet on pegs and mark where front suspension compresses to. And then:
2. jack up bike so that front forks lift off ground and measure how far the forks have 'stretched' ?
is that it?
John
Old 15-02-07, 05:59 PM   #5
Lissa
Just Ballast
Lissa's Avatar
Can you read this?
Old 15-02-07, 06:07 PM   #6
ejohnh
Can you read this?
Yep I could read that and I thank you very much for it - John
Old 15-02-07, 06:10 PM   #7
Lissa
Just Ballast
Lissa's Avatar
You're welcome John.
It was Pete really, he forgot to log me out and log himself in
Old 15-02-07, 06:14 PM   #8
Biker Biggles
Biker Biggles's Avatar
Call me old fashioned,but I don't think that's right.
I think static sag is the difference between fully extended and the level the bike sits at under it's own weight.When the rider gets on you get another level which is rider sag IIRC.Static sag can be adjusted by shimming the springs or preload adjusters,but the rest is dependant on spring rates,so requires new springs to adjust.I stand to be corrected though.
Old 15-02-07, 06:20 PM   #9
Lissa
Just Ballast
Lissa's Avatar
That was copied from Race Tech's information sheet that came with our new springs. I hope it's right, as that was the system we followed.
Old 15-02-07, 06:39 PM   #10
timwilky
timwilky's Avatar
The printout is pretty much how I understand sag to be measured. My understanding is that static sag is both bike and rider and is static as it is a statically applied load.
The displacement as a result dynamic load on the suspension as a result of actually riding would be meaningless unless it was recorded over a track and then the overall suspension adjusted to suit that track. Not practical for road riding.
Made To Measure Leathers Graciepants Suits 117 08-04-10 02:34 PM
Made to measure leathers. Tim in Belgium Suits 12 31-01-09 09:15 PM
Could someone measure? lodman27 SV Talk, Tuning & Tweaking 1 17-01-06 07:00 PM
Grunt or measure Mark_h SV Talk, Tuning & Tweaking 18 23-12-05 10:31 PM
Where to measure tread depth? Baldyman Tyres 10 30-08-05 08:50 AM
