Old 16-10-09, 06:39 PM   #11
sv_rory
Default Re: ABBA Stand fittings
Has anybody used the fitting kit for the rearsets? these are used if you want to remove the swingarm.
I got the kit but havent used it yet
Old 16-10-09, 06:41 PM   #12
Yep, much better than the swingarm ones I think. Removed my swingarm last winter
Old 16-10-09, 06:42 PM   #13
sv_rory
il be using the stand in a couple of weeks to remove the swingarm so il test them out then.
Old 16-10-09, 06:45 PM   #14
7755matt
7755matt's Avatar
To be fair, I don't see how they can fall off if they're fitted correctly. They have long pins that locate into the swingarm pivot.
As said they are very short, and if you fit the stand as in the abba video (with it on teh side stand) then the bike leans too much to get a decent fitment.
As far as I could tell it was all put in place, done up tight but as I raised the stand it fell off. I worked out the best way is to do it with the bike upright, so you can locate the pins fully.
Ive got the rearset mounts may well just use them next time
7755matt is offline   Reply With Quote
Old 16-10-09, 06:47 PM   #15
Then you'll see how little grease Mr Suzuki doesn't use on the bearings when he put it together
Check the shock pivot bearings on the swing arm too, because they get a lot more filth thrown at them.
Old 16-10-09, 06:48 PM   #16
I've left mine in place, as I can still ride about with them in place, although as I said, I've lost one of the other blighters
Old 16-10-09, 07:04 PM   #17
rigor
I would suggest that the mounts weren't sitting on the swingarm pivot bolt thingy correctly. If it's done up tight and they are fully engaged it can't slip off.
Old 16-10-09, 07:06 PM   #18
+1
Old 16-10-09, 07:21 PM   #19
FG1
Brollydolly, where are you located? Perhaps somebody could loan you theirs so the lads in the workshop have the items to copy. Maybe knock up a few spares at the time...
If local ish to Heathrow you are welcome to borrow mine.
Old 16-10-09, 09:55 PM   #20
Brollydolly
Originally Posted by sv_rory View Post
Ive got the abba stand and to be honest the sv fittings are a bit pants i wasnt hapy with having my bike raised with them. I sent them back to abba and got the hayabusa ones they fit so much better and the bike is more secure
Mine didn't seem all that secure either come to think of it, what diameter are your's and what length are they to the chamfer, pretty please x
As i'll get a set made up longer than the originals.
Abba stand Lucas Stuff Wanted 1 01-09-09 01:17 PM
Abba Stand & SK8? simonDyna SV Talk, Tuning & Tweaking 16 05-08-09 04:27 PM
Abba Stand Fittings - For Curvy Demonz Stuff Wanted 5 29-07-09 12:59 PM
Paddock stand/abba stand or? Ruthja2801 Bikes - Talk & Issues 18 26-02-09 12:20 PM
center stand / abba stand? New Leaf Bikes - Talk & Issues 3 29-01-08 01:58 PM
