Old 05-04-17, 10:02 AM   #51
biker_kev
Default Re: Lightened flywheels - group buy?
Hi Guys,
Having a problem trying to remove my flywheel. Tried a breaker bar on the rotor removal bolt yesterday, and it wasn't budging, so then had a go at it with my impact wrench - still not budging.
Left it overnight, then had another go this morning. Still no movement, so got a hot air gun on the centre of the rotor and gave it an extended go with the impact wrench, even backing off the bolt a turn or two and then using the impact wrench to see if it would help to shock it off. Started to see the bolt move a bit, but closely followed by slivers of metal coming out of the rotor where it was stripping the threads.
Any ideas on where I can go from here? At the moment it appears I'm well and truly f***ed..
Old 05-04-17, 10:11 AM   #52
I put a spanner on the rotor and locked it off against a crash bung to stop it rotating. Then I used a long pole on my breaker bar and put getle pressure on the bolt and increased the force gradually until the rotor came off. Took quite a lot of torque to get it moving.
You could try some plus gas on the rotor to help. There's a few tales of the rotors being hard to get off. So plus gas, then heat, then long poleb on breaker bar
Old 05-04-17, 10:49 AM   #53
biker_kev
Thanks for that idea Mav.
I've just found a spanner that fits the flats on the rotor, and it's just long enough to butt up against the crash bung. I'm going to have to re-tap the threads in the rotor though, as they are so damaged that I can't install the bolt without chewing the threads on that.
I'm just hoping that once I get it re-tapped there will be enough thread to hold when I get the breaker bar on it.
This f***ing bike's costing me a fortune!
Old 05-04-17, 12:14 PM   #54
DomP
Loving my heavy flywheel!
Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired
White 2011 YZF R125 sold
DomP is offline   Reply With Quote
Old 05-04-17, 05:52 PM   #55
SheepShagger
So whats the score now, are we waiting for many to send thier units in?
Sent from my SM-G935F using Tapatalk
SheepShagger is offline   Reply With Quote
Old 06-04-17, 01:25 PM   #56
SheepShagger
Anyone?
Old 06-04-17, 01:42 PM   #57
Grim-Lock
Grim-Lock's Avatar
I got a text asking what I wanted and a 3 week guesstimate for the service
Grim-Lock is offline   Reply With Quote
Old 07-04-17, 04:00 PM   #58
biker_kev
I'm still struggling to get my flywheel off.
Tap arrived this morning, so re-tapped the thread and at least it seems to be holding when I insert the bolt.
Tried lots of penetrating oil, left overnight, then a spanner on the centre flats, locked off against the crash bung, and a breaker bar on the bolt, with steady pressure applied, but the pressure spread the jaws of the first (cheap) spanner I used. Got a large adjustable wrench on the centre flats next, and used a hot air gun to get some heat into it and it's just starting to chew the centre flats.
My last hope is leaving the bolt in overnight under tension, then having another go tomorrow. My flywheel just seems like the one in one hundred I've read about that really doesn't want to come off!
Old 07-04-17, 04:26 PM   #59
Grim-Lock
Grim-Lock's Avatar
I really hope mine is not also one of the 100
Old 07-04-17, 08:13 PM   #60
Blapper
Blapper's Avatar
Sl0th86's gearbox sprocket was so tight nothing short of a 2000Nm rattle gun would shift it. I'd stop risking the flats of the bolt and go straight there if I were you.
Curvy lightened flywheels - £125 each millemille For Sale - SV's and SV related items 8 26-12-15 09:35 AM
Flywheels millemille Stuff Wanted 10 02-09-15 08:38 PM
Lightened flywheel - where? m1tch_1987 Bikes - Talk & Issues 4 21-10-13 05:45 PM
Flywheels rubberduckofdeath Bikes - Talk & Issues 11 05-09-05 10:31 AM
