04-11-15, 01:12 PM | #1 |
rear Break light on sv650s
Hi does any one know how to get to the rear break bulb on a sv650s o6 model. Thanks ged
04-11-15, 01:28 PM | #2 |
Re: rear Break light on sv650s
Hi Ged, try searching "rear brake light pointy". You will probably find what you need in a previous post. Pretty sure your brake lights will be by LED bulbs.
04-11-15, 01:38 PM | #3 |
Hi you would think,,,, but no posts out there.
04-11-15, 01:44 PM | #4 |
Yes, I have just had a look myself and you are right! Not easy to find a relevant thread. I found this one....
http://forums.sv650.org/showthread.p...=Brake%2Alight Do you have a fault with the brake light? |
04-11-15, 02:02 PM | #5 |
same old problem... with rear switch on bikes lol. The tail light is working and the brake adjustment light spring is working so i need to check the rear bulb..but how do you get to it on a sv650 o6 model. If it not bulb then its the break rear lever spring switch. Thanks for your help.
04-11-15, 02:36 PM | #6 |
Not sure what your symptoms are exactly. If the brake light is not coming on at all suggest use a voltmeter to see if you have switched current to the brake light unit (maybe at the connector between the rear light unit and the rest of the loom, which you should be able to access) when you operate the front lever and or brake pedal operated switch, with the ignition on. If you have current to the brake lights but no brake lights coming on, suspect a faulty light unit or poor connection from where you tested, to the unit. Hope that helps.
Hopefully someone else will be able to give a more detailed diagnostic. It will help if you describe your fault in detail. |
04-11-15, 02:42 PM | #7 |
Re access to the rear light unit, this video may help. Hope so anyway.
I haven't watched it right through.... https://m.youtube.com/watch?v=llvvuzkt0OI Update.. I have now and not that impressed, sorry! Last edited by Fen Tiger; 04-11-15 at 02:46 PM. |
04-11-15, 02:45 PM | #8 |
Does the brake light work with the front brakes?
04-11-15, 02:56 PM | #9 |
yes the front light break light works? so the back should work and it can not be the bulb!
04-11-15, 03:01 PM | #10 | |
rear break light problem | bluerider | SV Talk, Tuning & Tweaking | 1 | 03-08-10 11:19 AM |
Rear wheel Break Light 'On' Position | mikebrooman | SV Talk, Tuning & Tweaking | 17 | 06-01-10 08:48 PM |
Rear break Light unpluged. | mini_twin | SV Talk, Tuning & Tweaking | 3 | 07-08-09 05:34 AM |
Front break not lighting break light? | Baz | SV Talk, Tuning & Tweaking | 18 | 14-07-08 11:52 AM |
K4 SV650s Rear LED light Cluster question | Jon from Bristol | SV Talk, Tuning & Tweaking | 12 | 23-06-06 09:59 PM |
