Old 21-06-20, 09:50 AM   #21
embee
embee's Avatar
Default Re: K-tech front springs and spacer length
Originally Posted by tojo82 View Post
Was easy mate. Crack the top nut whilst still on the bike. .....
Yes.
A good tip is to loosen the top yoke fork stanchion clamp bolt before loosening the top cap as this can sometimes nip the cap threads enough to make it difficult to undo. The bottom yoke clamp will hold the stanchion enough to crack the top cap loose.
Old 21-06-20, 07:06 PM   #22
proze
Originally Posted by embee View Post
Yes.
Another good tip, thank you! I hadn't considered that at all.
proze is offline   Reply With Quote
Old 06-07-20, 08:56 PM   #23
DamoK4
Ended up buying .85 k-tech springs and 10wt silkolene maintain oil. Will have a go at getting it done this week. Keeping an eye out for a zx10r shock. It's your fault
Got Bibio's suspension setup bookmarked ready
DamoK4 is offline   Reply With Quote
Old 11-07-20, 04:24 PM   #24
DamoK4
Just got a gsxr 1000 k3 k4 shock in mint condition, will try and get the forks done and damper welded Monday. Postage on the shock is a week or two so if I can get the front set up properly I will be able to see what a difference the shock makes separately. It will be like two birthdays if i get it done right. I bought .85 springs but i weigh about 13.3, bit worried they might not be firm enough, it’s what k tech recommended for my riding style as I’m no racer by any means but after reading more old threads they may not be firm enough? Guess I could lose weight! Got a bit of a dad gut going on.
Old 14-07-20, 08:05 PM   #25
tojo82
Just a quick update all after having the improved front and rear suspension upgrades about a month ago. The bike is a totally different machine now. I used to feel scared around corners and it used to feel terrible on humpy roads. I feel so confident now and it twists and turns quickly and with ease. I wish I had done it years ago
tojo82 is offline   Reply With Quote
Old 14-07-20, 10:11 PM   #26
welcome to the dark side. you will now appreciate the SV's superb 650 v-twin. a standard SV feels wooden and bland compared to one with fettled suspension.
you can now see why a few of us put GSXR front ends on
Spacer size for RaceTech springs? loply SV Talk, Tuning & Tweaking 1 17-06-15 09:08 PM
Curvy swingarm bearing spacer length? Bibio SV Talk, Tuning & Tweaking 11 06-03-12 06:36 PM
K3 fork spacer length? RingDing SV Talk, Tuning & Tweaking 0 30-05-11 10:53 AM
GSXR 750 front end wheel spacer length? chakraist SV Talk, Tuning & Tweaking 3 28-09-09 05:45 PM
k5 fork spacer length? fast-lad SV Talk, Tuning & Tweaking 1 02-06-09 04:42 PM
