31-01-13, 04:32 PM | #1 |
Rust on brake disc.
Went to work on the bike Monday and was caught in some very wet weather, anyway when I got home I put the bike in the garage like I alway do. Well today I went to clean the bike and found the brake discs like this
I have never had this happen before. Is there any easy way to get it off or am I now f**ked and need new discs
Was SV650S K9 Now GSXR 600 K9 |
31-01-13, 04:37 PM | #2 |
Re: Rust on brake disc.
It will wear off in a few hundred yards when you ride it.Used to be quite normal on older cast iron discs.
31-01-13, 04:49 PM | #3 |
Not riding hard enough!
31-01-13, 04:51 PM | #4 |
Thanks you, glad i dont have to buy a new set
01-02-13, 01:17 AM | #5 |
I have cast iron discs on my beringer brake, you should see that after a few weeks away!
01-02-13, 08:28 AM | #6 |
The discs aren't rusty - those are stainless discs, it's metal particles in the brake pads, (a process called 'sintering'), which go rusty.
Completely normal, nothing to be concerned about - will take probably the entire first time you use the brake to go away.
Brake disc | jack930 | Stuff Wanted | 2 | 13-10-09 10:00 AM |
Brake Disc Problem | leegriffiths128 | SV Talk, Tuning & Tweaking | 25 | 17-11-08 06:38 PM |
