14-10-11, 11:11 AM | #1 |
Bridgestone 016
I've done one track day on this tire and had the pressure set right and now done bout 200 miles on it after the track day should my tire look like this because it feel very skidish now and not very comfidence inspiering It's a new brigdestone 016 with the dual compound.
Was SV650S K9 Now GSXR 600 K9 |
15-10-11, 02:12 PM | #2 |
Re: Bridgestone 016
Wouldn't have thought that was enough 'snot' to cause any problems or worry about.
15-10-11, 07:07 PM | #3 |
Re: Bridgestone 016
Nick, what are the pressure that Bridgestone recommend for these tyres? Thinking they might be different to the recommended pressures by Suzuki and hence why it feels naff.
15-10-11, 08:07 PM | #4 |
Re: Bridgestone 016
Are these the pro's? I just had these fitted to mine and they're hands down the best tyres I've ever used, great improvement on the previous 016's.
They do bubble up when hot though, mine are like that at the moment, once scrubbed off though they feel fine, don't worry.
Now: 12 Multistrada 1200 Was: 09 R1200GS Was: 08 CBR600RR Was: Blue SK5 Was: KMX125.. stolen.. |
18-03-12, 07:40 PM | #5 |
Re: Bridgestone 016
is their a standard 016 and a 016 pro version? ive just had a price of £215 fitted to loose wheels but dont know if they are pro or not
26-07-12, 10:24 PM | #6 |
Re: Bridgestone 016
First thing with tyres is that tyre pressures largely affect how the tyre wears. Double check tyre pressures and ask if Bridgestone specify different pressures from stock.
Secondly I'd say it's likely to be suspension setup. Either the front is too stiff or the rear is too soft. This video is pretty good for suspension setup: http://www.youtube.com/watch?v=mK3flKxf41U And this video can teach you what a tyre tells you about the bike's setup: 4:16 onwards applies to you... http://www.youtube.com/watch?v=JutNhZw1TB0 Hope this helps... It seems to have sorted out my problems (albeit most of the problem was having BT-016). I've changed to Dunlop D209 Qualifiers and the grip is fenomenal!! 40 miles and I had 2mm chicken strips. The front tyre is a lot slower to turn in than the Bridgestone but you get far more cornering stability. Something to bear in mind next time |
bridgestone bt-021 160/60/z17 | guzz316 | For Sale - Other Bikes and General biking items | 4 | 18-01-11 07:55 PM |
Bridgestone 016 anyone? | crazyhawk99 | Tyres | 15 | 28-08-09 04:44 PM |
Bridgestone 021 | Stu | Tyres | 27 | 11-01-08 07:48 PM |
bridgestone: 020 or 014? | rednorvs | Tyres | 3 | 16-03-06 09:10 PM |
Bridgestone 014 | Ransom | Tyres | 1 | 17-05-05 05:19 PM |
