Old 24-07-20, 10:04 AM   #1
SWTH
Junior Member
SWTH's Avatar
Default Oil pump gear replacement
I’m looking to take my SV650 on track soon and it appears the stock nylon oil pump gear isn’t up to much. JHS do a replacement steel item, has anyone here fitted one and if so, anything I should be aware of? Also, is there an exploded diagram anywhere of the SV650 engine from the clutch side?
Thanks in advance.
SWTH is offline   Reply With Quote
Old 24-07-20, 01:13 PM   #2
SV650rules
Default Re: Oil pump gear replacement
Some sites with exploded diagrams of assemblies..
https://www.oemmotorparts.com/oem4.a...05&L=SU4_-4389
https://www.fowlersparts.co.uk/brows...ur/all-colours
https://www.robinsonsfoundry.co.uk/s...!sv650xoilpump
2016 SV650 AL7
Gear selector shaft seal replacement? andrewsmith SV Talk, Tuning & Tweaking 0 27-05-14 09:10 PM
Help finding replacement gear lever on a ZX6R TheRamJam Bikes - Talk & Issues 3 04-03-12 08:40 PM
Fuel pump replacement in time for AR! Noble Ox The Madlanders 12 05-08-10 01:45 PM
Replacement Gear / Rear Brake Levers..? Scoobs Idle Banter 5 22-01-10 10:17 AM
Replacement pegs and gear/brake levers zigrat SV Talk, Tuning & Tweaking 1 23-07-09 10:27 AM
