Old 09-08-20, 02:10 AM   #1
Zim
Zim's Avatar
Default Sorry, but, what's this bit called?
I'm trying to get my Suzuki SV650S K9 pointy together for sale after being SORN for a while. A bad back forced me off the road and I'm just not confident it will ever be good enough again to confidently ride again without thinking it could go mid corner!
Anyway, my optimate seems to have stopped working so I need to get the battery out to charge it up and see what's going on. One of the bolts that hold the side cover trim panels has stripped so I need a new one. Couldn't fit it in the microfiche, anyone help me with the official name of the panels or a link to which bolt it is or something.
Suzuki SV650S K9
Kawasaki ZZR 400
Yamaha XV535
Yamaha YB100
Zim is offline   Reply With Quote
Old 09-08-20, 04:57 AM   #2
Default Re: Sorry, but, what's this bit called?
Side infill panel?
If it's the same bolt as the curvy, then I've got one knocking about you can have. Otherwise a panhead bolt will do the trick
Old 09-08-20, 06:55 AM   #3
Seeker
Seeker's Avatar
Frame cover:
https://www.fowlersparts.co.uk/parts...0s/frame-cover
2016 SV650AL7
2023 GSX-8S
Old 09-08-20, 11:42 AM   #4
Zim
Zim's Avatar
Thanks fellas.
That's the one!
09139-06107
I'll double check my stash before asking for one. I had some chewie stainless stuff left over I didn't put on, maybe it was one of those. Thanks though, it was late last night and the searches I trying were coming back with nothing. Always obvious and easier once you've seen a more sensible description than you can muster from your own noggin in the early hours!!!!
Suzuki SV650S K9
Kawasaki ZZR 400
Yamaha XV535
Yamaha YB100
What's this called? oOTomOo Bikes - Talk & Issues 5 19-05-13 08:40 PM
What is this bit called? hongman SV Talk, Tuning & Tweaking 8 22-10-10 02:41 PM
She called! Spiderman Soho Massive 142 27-08-09 08:37 AM
What is it called? Mike2165 Idle Banter 11 31-10-07 08:23 AM
just called in to say Hi airbox South & West Surfers 9 01-07-05 10:44 AM
