08-08-06, 12:23 PM | #1 |
Rear Brake Pipe rubbing on Swingarm.
Has anyone else had this happen on their pointy If so how did you cure it. I have a K5 which has done 2300 miles and the brake pipe has worn through the paint on the swingarm.
Dealer has never seen it happen before, has repainted the swingarm and put a foam sticker on the swingarm where it rubs, 150 miles later and i am nearly through the foam sticker |
08-08-06, 12:25 PM | #2 |
I have exactly the same thing happening, but I have a K3 which is a polished silver S/arm, so it doesn't really matter, to be honest it is the only clean bit on it!
08-08-06, 12:30 PM | #3 |
Same happened on mine, even to the point where there seems to be an indentation on the swingarm.
As it happened when I changed footrest hangers the pipe was pulled tighter, so no longer touches, but that doesn't solve your problem. |
08-08-06, 12:44 PM | #4 |
Same on my K5, apart from i have a hugger so it's rubbing the paint of the hugger instead of the swing arm
08-08-06, 01:45 PM | #5 | |
08-08-06, 01:59 PM | #6 |
dont do it on my k3.
08-08-06, 04:46 PM | #7 | |
Cleaning all around the rear wheel / swingarm / rear brake caliper | Camel | SV Talk, Tuning & Tweaking | 12 | 28-04-08 02:00 PM |
Brake light not working when rear brake is used.. | StreetHawk | SV Talk, Tuning & Tweaking | 10 | 16-04-07 03:40 AM |
curvy swingarm and rear wheel | riktherider | SV Talk, Tuning & Tweaking | 2 | 27-02-07 06:36 PM |
rear brake pipe bracket!! | kwak zzr | SV Talk, Tuning & Tweaking | 6 | 09-03-06 12:31 AM |
rear brake pads/disc rubbing | will | SV Talk, Tuning & Tweaking | 4 | 02-03-06 10:19 AM |
