Old 15-06-19, 06:30 PM   #1
Yeti
Junior Member
Default Sv650
Hi
I have a question about my Sv I changed the engine and now the dashboard does not work but the lights work,starter button does not work have checked all the fuses all ok check ignition that’s fine. If anyone has any ideas please let me know many thanks
Yeti is offline   Reply With Quote
Old 16-06-19, 06:47 AM   #2
Seeker
Seeker's Avatar
Default Re: Sv650
I have no idea, on the other hand you haven't given us too much information.
Is it a curvy or a pointy?
If it's a pointy is the engine from the same model year?
"The dashboard does not work" does this mean no idiot lights either (neutral, high beam, turn signal, oil pressure)?
"The lights work" can you switch low beam to high beam? How about turn signals?
"The starter button does not work" does this mean the engine won't turn over or it won't fire?
Have you tried reseating electrical connectors?
Old 16-06-19, 07:43 AM   #3
Yeti
Junior Member
Default Re: Sv650
It is a Carey the lights go from low to high beam the bike will not start or turn over on the button flashes work
Old 16-06-19, 10:42 AM   #4
Seeker
Seeker's Avatar
Default Re: Sv650
This is a good thread to follow (it saves me typing):
https://www.svrider.com/forum/showthread.php?t=190657
briefly - check the green connector under the tank, it is a common failure point.
If that's ok, try shorting together the two heavy duty contacts on the starter relay (the lowest connections in the photo in post #2). The engine should turn over (make sure it's in neutral).
Note: there is a lot of current flowing here so use a jumper cable to bridge the connector. Only a brief connection is required to verify the starter motor will work and touching the connectors will generate a spark. Be careful.
Old 16-06-19, 11:48 AM   #5
Yeti
Junior Member
Default Re: Sv650
Hi
Have checked green block that is ok also turns over fine also will start doing that
Old 16-06-19, 12:38 PM   #6
Seeker
Seeker's Avatar
Default Re: Sv650
so the starter relay isn't getting power which implies you have an interlock problem. To energise the starter relay the clutch switch needs to be made, starter pressed (duh), engine stop switch to "on" and the side stand relay energised - which needs either neutral or the sidestand switch.
If this was working before the engine swap it would point to the neutral switch since it came with the new engine (presumably?). If you pull the clutch lever with the side stand up will it run? (I'm trying to remember if it's supposed to because the new SV doesn't need the clutch to be pulled in, in neutral).
Here's the interlock diagram:
https://www.manualslib.com/manual/11...age=306#manual
Old 16-06-19, 01:38 PM   #7
Yeti
Junior Member
Default Re: Sv650
Hi
I have tried that but there is no power to the start button with the side up or when I pull the clutch lever in or when in neutral it is a 2001 model
Old 16-06-19, 03:15 PM   #8
Seeker
Seeker's Avatar
Default Re: Sv650
Then you need to start checking voltages. A good place to start is at the orange/yellow wire at the turn signal/sidestand relay, with the ign on there should be 12V (ie battery voltage). If there is, then measure the voltage on the orange/black wire at the turn signal/sidestand relay.
Is the neutral light working?
I'm hoping someone else can chime in now because I have to leave. Good luck.
Old 16-06-19, 03:35 PM   #9
Yeti
Junior Member
Default Re: Sv650
Ok thanks will try that and no neutral light is not working
sv650 to sv650 to sv1000 to sv650 to MT-03 Anybody owned one? ian505050 Bikes - Talk & Issues 9 11-09-11 10:50 PM
2000 sv650 stanchion on a 2004 sv650? kaimera SV Talk, Tuning & Tweaking 6 09-06-11 10:06 PM
Red SV650 Seat, Oxford Indicators & SV650 bits. MattSV650 For Sale - SV's and SV related items 2 09-04-11 09:43 AM
G-PACK for SV650 SV650S SV 650 SV650 S - EFI MODELS - Timing Retard Eliminator ThEGr33k SV Talk, Tuning & Tweaking 0 25-11-07 12:22 AM
will a 2002 sv650 s cylinder head fit my 99 sv650? bugsy46 Bikes - Talk & Issues 2 07-04-07 04:26 PM
