08-02-17, 01:20 PM | #1 |
Help! Front sprocket too tight!
Is there any secret method to getting a front sprocket nut off? Tried everything! Even took it to a bike garage and he put his gun on it and wouldnt budge, had a go at it with a big bar and no luck! He mentioned heating it up and having another go but will it damage the oil seal? Any tips would be appreciated!
08-02-17, 01:28 PM | #2 |
Re: Help! Front sprocket too tight!
soak it in pluss gas for a few days might help.
08-02-17, 01:39 PM | #3 |
Yeah blapper mentioned that to me as well! Hmmmm
Sent from my iPhone using Tapatalk |
08-02-17, 01:41 PM | #4 |
Do you know where i can get it from???
08-02-17, 02:04 PM | #5 |
halfords or car factors.
08-02-17, 02:17 PM | #6 |
Oh! Looks like im going halfords on the way home then. Thanks mate
08-02-17, 03:17 PM | #7 |
Are you sure the lock washer is completely clear of the nut?
08-02-17, 03:27 PM | #8 |
Yeah im pretty sure, i mean all you do is flattern 1 side against the nut dont you? There is nothing touching the nut
08-02-17, 04:03 PM | #9 |
Assuming its a RH thread ?
The nut may have stuck to the sprocket by corrosion - plus gas will help.
08-02-17, 04:37 PM | #10 |
Yeah it is RH thread, it does look pretty dry down there so im going to pickle it in plus gas and give it another go with a breaker bar
Help! Front sprocket nut too tight | sl0th86 | Stuff Wanted | 2 | 08-02-17 01:21 PM |
Fitted larger sprocket, chain too tight. | mase_tw | Bikes - Talk & Issues | 30 | 18-10-13 03:21 PM |
Standard front sprocket, bigger rear sprocket, how many more links in chain required? | Holdup | Bikes - Talk & Issues | 6 | 27-02-12 12:40 PM |
Rear Axle bolt -how tight is tight | MavUK | SV Talk, Tuning & Tweaking | 4 | 02-03-08 11:47 PM |
Over tight front sprocket | Paws | SV Talk, Tuning & Tweaking | 7 | 07-09-06 05:59 PM |
