Old 08-05-18, 09:37 AM   #1
Strangwooduk
Strangwooduk's Avatar
Default GSXR front Swap Help
okay so i originally started doing the front for my bandit that got sold but kept the front
the yokes i have are 55mm yokes with 54mm forks but sorted that with a shim
now then
i had the bandit stem pressed into the yokes
i have heard the bandit stem is the same as the SV stem is that correct ?
as the stem is poking out about 3-4mm out the bottom of the yoke and the bottom race bearings wont fit its just loose
any advice >?
thank you
First time on V-Twin - Never looked back
Gen 1 Curvy 1999
Strangwooduk is offline   Reply With Quote
Old 08-05-18, 05:39 PM   #2
Default Re: GSXR front Swap Help
the simple solution is to stick with the GSXR stem and buy the correct top bearing. this is well documented to be the correct solution.
best advice i can give is dont fek with the yokes and fit the correct forks, axle and wheel for the job. messing with "bitsa (not busa)" front ends is always a recipe for headaches.
Old 09-05-18, 07:38 AM   #3
Strangwooduk
Brilliant............
any idea what yokes will fit a TL top yoke and 54mm forks
looks like im gonna have to buy some more
Gen 1 Curvy 1999
GSXR front end swap? Gaz.sv650 SV Talk, Tuning & Tweaking 7 30-06-11 11:30 PM
GSXR Front End Swap Kemp10 SV Talk, Tuning & Tweaking 43 02-12-08 04:47 PM
yes, another gsxr front end swap, done Bibio SV Talk, Tuning & Tweaking 25 16-09-08 04:07 PM
GSXR front end swap - front tyre profile. Khewett SV Talk, Tuning & Tweaking 12 11-05-06 11:24 AM
