Old 14-12-10, 07:58 PM   #1
skithepowder
Default Polishing out a scratch?
After dropping my bike at about 10mph about 6 weeks or so ago,the only real damage thanks to the crash bungs was a broken gear lever and indicator which I replaced. However, I did get some very very light scratches to the front fairing. I've attached a picture, it is only the circled bit, although the lighting and reflections in the photo make it look like there are a few paint chips elsewhere there aren't at all. It is very light, as you can see it hasn't even made it through the sticker in most parts and almost looks like a bit of dirt until you brush your fingers against it and realise it doesn't come off.
I was thinking surely some scratches this light should just polish out? If so I've never done anything like that, so what do I need to use/do to clean it up? And to top it all off where can I get and how much does it cost for a replacement decal so that it will be back in pristine condition? And how do you remove/apply a decal, do you use a heat gun or something?
Thanks
Old 14-12-10, 08:02 PM   #2
TomSV
Default Re: Polishing out a scratch?
Well first of all I've been lurking around this forum in the shadows
So this will be my first postso...HI
It all depends on how deep the scratch is. I detail cars as a hobby and the best way to correct a scratch is via machine polishing.
Can you feel the scratch with your finger nail?
Tom
Old 14-12-10, 08:10 PM   #3
skithepowder
Tom
Well, first of all welcome to the forum.
In response to your question, yes, you can feel it with your nail, the majority of it only just. Most of it I wouldn't really describe as a scratch, its more like a graze, a roughing up of the paint, but you can feel it. The clear white line underneath the 6 is much more like a scratch, although I wouldn't describe it as really deep that part you can definitely feel under your nail.
Old 14-12-10, 10:04 PM   #4
missyburd
T-cut, an old rag and a lot of elbow grease...
welcome to the forum too.
Old 14-12-10, 10:08 PM   #5
Sadly elbow grease as MYC said!
Old 14-12-10, 11:16 PM   #6
TomSV
Personally I think t-cut is the worst thing you can use as the abrasive doesn't break down and can seriously dull the shine.
I'll be more than happy to send some spare polish I have laying around
Old 14-12-10, 11:26 PM   #7
christian1000
Autoglym super resin polish does the trick for me. In combination with the afor mentioned elbow grease.
Old 15-12-10, 12:24 AM   #8
Tom
+1 on both counts, all your get with Tcut is a shiny scratch.
My friend does detailing for a living and he advised on the polishing kit i got, you will not get a better flawless shine than with a random orbit polisher, correct pads and polish / compound.
Old 15-12-10, 06:24 AM   #9
TomSV
SRP is good but it's a filler and will only mask the defects.
+1
Old 15-12-10, 09:20 AM   #10
missyburd
Well I only mentioned because I've used it and it did the trick for me. Didn't notice any difference to the finish. If you're on a tight budget I think it would have to do but I'm sure it's worthwhile to spend a bit more pennies and do it properly.
Watch Scratch removal ? hindle8907 Idle Banter 1 12-04-10 10:19 AM
Helmet scratch removal 999nutta SV Talk, Tuning & Tweaking 3 16-03-08 11:36 PM
Polishing out a scratch in the exhaust. creamerybutter SV Talk, Tuning & Tweaking 4 25-07-06 12:22 PM
To scratch or not to scratch? Jdubya Idle Banter 17 21-06-06 10:49 PM
Scratch on swingarm rpwoodman SV Talk, Tuning & Tweaking 1 19-11-05 04:47 PM
