01-07-08, 12:15 PM | #11 |
Re: Gear Shift Lever??
SV Spares also do pattern ones, which are spring loaded, so if you drop it, it doesn't snap off.
I just haven't got round to fitting mine yet. |
01-07-08, 12:19 PM | #12 |
Springy ones are Curvy only
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
01-07-08, 12:28 PM | #13 |
how much do suzuki want for one?
01-07-08, 01:29 PM | #14 |
01-07-08, 09:21 PM | #16 | |
daylight robbery. Just pray you get lucky like me and get one for £20. If only a brake lever would appear then perhaps i could get rid of my fixer peg. |
01-07-08, 09:23 PM | #17 |
give george white superbikes a call www.georgewhite.co.uk in swindon, thats where i got mine from after a ...... mishap !
they were in stock for a k4. |
02-07-08, 07:36 AM | #18 |
Guess what?
Suzuki dealers sell Suzuki parts.
02-07-08, 08:14 AM | #19 |
02-07-08, 08:32 AM | #20 |
If you have an 04 or newer sv650 it will have the gear lever that rotates on a separate lug (that's prone to unscrew and fall out) instead of the older design where the lever pivots on the footpeg.
Whilst gear levers specifically for the k4+ seem hard to find try a search on ebay for hayabusa gear levers, I broke the lever on my k4 a month or so ago and after some searching forums found the hayabusa lever was a direct replacement so got one from here on ebay: http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=014 It was a perfect fit and looks better than the original, cant be bad. You will also need a pair of circlip pliers to remove the old lever and make sure and check the lug the lever pivots around is still screwed in tight, if not a bit of threadlock and do it up again is in order. en4rab |
Gear shift lever | st220_mike | Stuff Wanted | 10 | 25-02-09 09:20 PM |
Gear Shift Lever | george650 | Stuff Wanted | 7 | 11-06-08 04:26 PM |
another gear shift lever | jcuff86 | Stuff Wanted | 8 | 09-06-08 09:37 PM |
Gear shift lever | dizzyblonde | SV Talk, Tuning & Tweaking | 5 | 07-05-08 09:16 PM |
Gear shift Lever | Tris | SV Talk, Tuning & Tweaking | 4 | 02-04-05 06:36 PM |
