Old 15-02-20, 05:40 PM   #6781
Kenzie
Kenzie's Avatar
Not what you want to see when you open up and under water camera. Paid a few pounds for this Fuji XP somethings or other as it was listed as not powering up. I wonder why... Plus side is I can use the power button from this one to replace the bodged one on my other XP.
Sent from my Xperia using Tapatalk
Old 15-02-20, 09:02 PM   #6782
johnnyrod
johnnyrod's Avatar
Oh dear, which bit ha leaked do you think?
Old 15-02-20, 10:37 PM   #6783
Kenzie
Kenzie's Avatar
I think the battery/sd door leaked. There was corrosion on the battery contacts as well as the main board. Screen seems to be ok though but I have no way of testing it. The ribbon cable socket for the GPS unit fell off the main board as well. Have you tested out yours yet?
Old 15-02-20, 11:05 PM   #6784
johnnyrod
johnnyrod's Avatar
I submerged it in the sink earlier! It's working fine and in immaculate condition, so I doubt it's been used in the sea. The buttons are easy to press; my older Vivitar one has quite sticky buttons ever since its first dunk in the oggy, despite long soaks in fresh water. It comes with a small tub of silicone to lube the O-ring on the battery door, but there's no way to reach the buttons, they need it! Annoyingly the XP needs you to open the battery/SD card door to recharge it. I know it would have needed a hole in it somewhere to do so, but I do wonder if it's a weak point in the design. I don't believe it has GPS though? A quick google says the much older models do (XP30) but mine doesn't, odd.
Old 16-02-20, 08:28 AM   #6785
Kenzie
Kenzie's Avatar
I think my busted one was an XP30. You can buy a separate usb charger for them and just eject the battery rather than undoing the smaller fold down flap.
Old 16-02-20, 07:12 PM   #6786
johnnyrod
johnnyrod's Avatar
Mine just has one flap, its got the battery card and USB and HDMI sockets all under there
Old 16-02-20, 08:42 PM   #6787
Kenzie
Kenzie's Avatar
Well at least they got rid of that silly feature. One seal on the side instead of two.
Old 18-02-20, 10:14 PM   #6788
johnnyrod
johnnyrod's Avatar
Kenzie
133328908349
Old 19-02-20, 06:41 PM   #6789
Kenzie
Kenzie's Avatar
Thanks Johnny, was busy at work today so missed the end.
Old 22-02-20, 05:53 PM   #6790
Kenzie
Kenzie's Avatar
Decided to finally get rid of my VW project van. I've had it nine years and no closer to getting it done. Plus side is my wife said the extra space in the massive car port will be freed up for more motorcycles...
I've also had a little clear out of cameras, Chinon CE-4, Centon DF300, a couple of beer can cameras and a bunch of lenses.
