Old 06-01-20, 11:35 AM   #1
Craig380
Default Complete throttle body & injector assembly for K3 - K6 bikes
Complete throttle body assembly for a K3 - K6 SV650 (may also work with the later K7-onward machines, I'm not sure). In good condition, came from a low-mileage bike.
The assembly has both injectors, the STV motor (which turns freely using the nut), throttle cable guides & pulley, all linkages, all the original electrical connectors, and even the fuel hose that connects to the fuel pump outlet so it's ready to fit as a unit (doesn't include the inlet rubbers).
The assembly has an A2 restrictor plate fitted too (which stops the main throttle butterflies opening more than halfway) which is retained by a single screw.
Asking £35 including postage (UK mainland only).
throttle case assembly housing lukeyb Stuff Wanted 0 26-01-15 06:20 PM
complete throttle assembly and right hand switchgear pointy michaelr1 For Sale - SV's and SV related items 0 08-06-12 12:01 AM
NAked throttle assembly/switchgear DarrenSV650S Stuff Wanted 2 02-10-10 02:17 PM
Throttle cable assembly Torn-Thorax SV Talk, Tuning & Tweaking 2 26-02-07 08:37 AM
Scottoiler: Dispenser Assembly & Injector. Akula Idle Banter 2 06-05-06 08:23 AM
