09-03-07, 08:57 PM | #1 |
metal tank?(map holder advice sort)
Hi
Does the K6 have a metal tank? What is the best tank map holder? |
09-03-07, 09:06 PM | #2 |
Re: metal tank?
they all have a metal tank, as for a holder im not sure???
09-03-07, 09:09 PM | #3 |
Re: metal tank?
Depends What You Want It For??
Just A Map Holder Or Tankbag Aswell, If Its Just A Map Holder You Want Get Your @rse To Lidl £2.99 |
10-03-07, 09:20 AM | #4 |
Re: metal tank?
The oxford tank bags have a map holder if you unzip the tank bag from the base there is a map holder on the base!
10-03-07, 09:45 AM | #5 |
Re: metal tank?
The Lidl ones are the same and are only £15 but you'll have to be quick.
11-03-07, 10:01 PM | #6 |
Re: metal tank?(map holder advice sort)
I've just bought a magnetic map holder from LIDL supermarket. I can't find the receipt, but I think it only cost £2 or £3. Its also got a strap to attach around the head stock but its probably saver to remove this. This is purely a map holder only. I've not tried it out yet, I'll let u know tomorrow if its any good.
11-03-07, 10:09 PM | #7 | |
11-03-07, 11:22 PM | #8 |
Thanks. I feel right at home ! I've tried the Lidl one out. It seems okay, but the front of it lifts in the wind. I tried it back to front and its better. The strap on it would foul the steering so I wouldn't use that. Can't complain for £2 or £3.
12-03-07, 05:41 PM | #9 |
I got one of the Lidl tank bags, and put it on today- with the front strap bit too, and that never fouled the steering..
12-03-07, 09:16 PM | #10 |
The one I've got is just a map bag, not a tank bag. The strap is attached by 2 clips and is about an inch wide. It seems to route very close to the ignition barrel.
Fuel Tank Stay/Holder Upper Thingy? | COLZO | SV Talk, Tuning & Tweaking | 12 | 19-02-09 11:12 PM |
Plumbing advice (Sort of) | andyb | Idle Banter | 2 | 01-06-08 04:35 PM |
Is the fuel tank on my sK5 metal or plastic? dumb question I know | Paul the 6th | Bikes - Talk & Issues | 2 | 16-01-08 10:36 PM |
Tank spacers - advice req'd | netsurfer | SV Talk, Tuning & Tweaking | 15 | 06-01-07 03:58 PM |
Motrax Tank Pad Fitting Advice? | PoRk ChOp | Bikes - Talk & Issues | 15 | 07-01-05 12:48 PM |
