24-11-08, 06:41 PM | #1 |
oil issues
hmm after reading the recent stories about running oil low I was a little worried about changing my oil myself for the first time but I took my time,
(its a K6 on its 11k service) followed the instructions and it was fine. I've been checking for drips or anything that I've not tightened up properly, admittedly I haven't been checking the level as rigorously as I should but it was fine for 2-3 days after I changed it. Today 3-4 weeks after, I started my bike to take a trip from work, got 50 yds to the traffic lights off site and it died with the oil light on, I pushed it back to the bike shed and called my wife who graciously came and rescued my stupid ass, I topped the oil up and everything seemed fine. took it steady on the way home and nothing seemed out of the ordinary, is there anything I should check for or do? any idea what could cause it to lose that much oil without dripping it everywhere? it hasn't been burning it that I've noticed, surely that much gone would result in some serious blue smoke? |
24-11-08, 06:54 PM | #2 |
Re: oil issues
Did you check the oil with the bike up right and after the engine had ran for a little?
How much oil was needed to fill her up? If there are no signs of a leak and no blue smoke I would guess you underfilled it the first time around. Last edited by Dangerous Dave; 24-11-08 at 07:00 PM. |
24-11-08, 07:01 PM | #3 |
Re: oil issues
You say it died with the oil light on? Was oil light on when it was running or did it just come on as the motor stopped?
24-11-08, 07:11 PM | #4 |
Re: oil issues
Came on as it stopped as far as I can remember.
the bike was on a paddock stand when I filled it, I ran it and then topped it up to the line (or thought I had) maybe I did just screw up, but why so long to show up? Weirdness, least topping up seems to have sorted it. I'd guess 100-200ml to top it up. |
24-11-08, 07:23 PM | #5 |
Re: oil issues
Ah... there is your problem. When the bike is on a rear paddock stand it jacks the back up, this pushes the oil to the forward as the nose is lower than normal and gives a false reading.
The bike was most likely under filled, always check the oil level with the bike upright on a level surface and with both wheels on the ground. |
24-11-08, 07:33 PM | #6 | |
Re: oil issues
Thanks for that, would explain the underfilling, still not sure what set it off today, ah well, looks like no harm has been done and a vital lesson has been learned (now) thanks for the advice guys |
24-11-08, 07:43 PM | #7 |
Re: oil issues
24-11-08, 07:47 PM | #8 |
Re: oil issues
This reminds me, I need to wire up an LED for oil pressure, though it'd too late once that's on usually.
I put a couple of blocks of wood under the sidestand to check mine when I get in after a run, every time. It's easy to hold the bike and check the spy glass myself that way. Be careful if you do it that way though, don't pull the bike too far towards you |
24-11-08, 07:54 PM | #9 |
Re: oil issues
Well then something else caused the motor to stop. The oil light does come on when the engine stops, as an oil pump which isn't turning creates no pressure.
24-11-08, 08:39 PM | #10 | |
Re: oil issues
fill it up without stand and than put bike on stand and see where level is and use it in future. on stand my is close to very top of window. |
3 Issues | Phaelok | Bikes - Talk & Issues | 11 | 28-10-08 11:06 PM |
DNS Issues | Jelster | Idle Banter | 6 | 05-02-07 05:59 PM |
more clutch issues | timwilky | SV Talk, Tuning & Tweaking | 2 | 14-05-06 07:55 PM |
For any one with knee down issues............ | svrash | Bikes - Talk & Issues | 7 | 05-05-06 11:37 AM |
Oil issues..... | lynw | SV Talk, Tuning & Tweaking | 13 | 18-11-04 08:36 PM |
