25-10-09, 07:19 PM | #22 |
Re: i'z been spraying'z
Some kinda of Evel Keneval esq paint job is in order I think.
25-10-09, 07:20 PM | #23 |
Evel Knievel
yeah but he had stars and stripes didn't he?
25-10-09, 07:21 PM | #24 |
Aye, and then you could get a nice set of white leathers with tassles on, then you'd look the biz
25-10-09, 07:21 PM | #25 |
What paint have you used for this?
25-10-09, 07:46 PM | #27 |
acid etch! :O
Really you wanted to use an adhesion prmoter then 2k primer, Upol do awesome products for that. Etch is most commonly used and really best for aluminum parts. Make sure the plastic was as smooth as glass and not "fluffy" from prep marks, the little fibres will lift through the paint. |
25-10-09, 07:53 PM | #29 |
Bright yellow so u can be seen numpty head
25-10-09, 07:53 PM | #30 |
I'm not talking about aerosol
You get it to go through the gun. Also the reason cans splatter is because the components inside aren,t mixed correctly and are under temperature. I use and adhesion promoter from upol in an aerosol for small jobs, it allows 2k etc straight over. i'll get the name of it in a monent. |
