Old 25-09-19, 05:50 AM   #11
Scittyf
Default Re: Aftermarket Speedometer for 2000 SV650 (Y)
I've found the first generation speedometer pretty inaccurate too. Below 50mph it under reads then over 50mph it starts to over read.
Anyone else noticed that?
Scittyf is offline   Reply With Quote
Old 25-09-19, 06:50 AM   #12
Seeker
Seeker's Avatar
I think any aftermarket gauge would look odd till you got used to it, generally it's making a professional looking mount that's more of an issue.
Here's a thread on the US site about installing a Koso gauge, unfortunately he used Photobucket as an image host and they now watermark (by blurring) their images.
https://www.svrider.com/forum/showthread.php?t=113175
I'm guessing you've seen the instructions: https://kosonorthamerica.com/instructions/BB642W10.pdf
I did see this too: https://kosonorthamerica.com/shop/mo...0-adapter-kit/
Old 25-09-19, 08:52 AM   #13
daktulos
daktulos's Avatar
If you can find an original speedo which has been involved in a crash, you should be able to unsolder the display to move it across - it's normally the gauge which gets broken.
daktulos is offline   Reply With Quote
Old 25-09-19, 02:49 PM   #14
Bike27
Originally Posted by bezsv650 View Post
The original speedo is working but the lcd has a black patch I can't get rid of. I can live with it but it is covering up the mileage which may be awkward on resale. I'm sure a used one would be a good solution, I just like the look of these digital ones. I'm just worried the wiring would be too tricky
Replacing O.E. Suzuki gauges with aftermarket ones is just as likely to be awkward on resale. The golden rule is that standard bikes always sell best (or ones with what are widely considered to be desireable mods. e.g. an aftermarket rear shock).
Personally I generally wouldn't touch any roadbike with non stock gauges unless it was very cheap as I'd just assume it had either been in an accident or done a very high mileage (prior to the speedo change) or both.
Plus I'd probably hate the new gauges and just want to fit original Suzuki ones anyway.
In short, if you are concerned about future resale, keeping your bike looking like Mr. Suzuki intended is definitely your best option.
2018 SV650AL8
2001 KTM 640 Duke2
2015 KTM 390 Duke
Bike27 is offline   Reply With Quote
Old 26-09-19, 03:37 PM   #15
bezsv650
Yes, thanks. Adapter kit is not for the 'Y' model unfortunately.
bezsv650 is offline   Reply With Quote
Old 26-09-19, 03:39 PM   #16
bezsv650
I think you are right. I will keep looking for a used one online.
Old 26-09-19, 11:31 PM   #17
Bike27
A professional repair on it might be another option, there are certainly businesses that specialise in gauge repair, although a used gauge might be cheaper.
Or you could try a D.I.Y. repair - the following guide reckons a few minutes with a hair dryer applied to the BACK of the display could do it
http://www.exisle.net/mb/index.php?/...sumer-devices/
2018 SV650AL8
2001 KTM 640 Duke2
2015 KTM 390 Duke
Old 28-09-19, 08:54 AM   #18
dirtydog
Knob faced knobster
dirtydog's Avatar
Sounds like screen burn, I've not had sv clocks apart enough to see if it's actually viable but it may be as simple as needig some new polarising film/filter.
May only work if you're handy with a soldering iron etc
2001 SV650 in shimmerin green, Not broken anymore
Old 22-10-19, 12:11 PM   #19
gt alex
Hi just replaced mine after the retifier failed killing everything including battery cdi headlight and tacho.
I bought a chinese one which seems good. heres a couple of things that may help.
Modern tachos often don't use coil signal, they use a pulses from the crank trigger. I ran a wire from the pulse in ata the cdi. also the standard speedo rotor has 4 magnets and worked well with the aftermarket speedo.
Hope this is helpful
gt alex is offline   Reply With Quote
Old 07-12-19, 09:25 AM   #20
DonSteve
Junior Member
Originally Posted by R1ffR4ff View Post
I looked into this before I managed to repair my blown Rev counter and there didn't seem to be an easy option.I toyed with the Idea of one of these,
https://www.ebay.co.uk/itm/7-Color-L...YAAOSwFTddaDX0
I too have a blown tacho (I think), it was a long time since this posting but can you remember how you diagnosed/fixed it?
DonSteve is offline   Reply With Quote
2000 Suzuki SV650 (Y) - Speedometer Not Working bezsv650 SV Talk, Tuning & Tweaking 17 07-12-19 10:09 AM
99-02 naked SV650 clocks/speedometer Alexander94 Stuff Wanted 0 28-02-15 04:22 PM
2000 sv650 right hand side front fairing in dark blue and aftermarket exhaust wanted Danban Stuff Wanted 4 26-04-14 02:45 PM
Speedometer Out, Odometer Frozen - 2001 SV650 Naked jmoorse SV Talk, Tuning & Tweaking 4 22-12-06 10:46 AM
Intermittent Speedometer (2000) rrbarna Bikes - Talk & Issues 5 31-08-06 11:47 AM
