30-12-06, 07:47 PM | #11 | |
30-12-06, 07:47 PM | #12 |
Rust looking chain? mmmm i use wd40 a toothbrush and a rag you can evan read DID on the links
30-12-06, 07:49 PM | #13 |
How do kwak zzr.
i did that the other day, it seems that when i come back off a ride its all flung off.... |
30-12-06, 07:56 PM | #14 |
yea when its clean spray it with pj1 or something sim and let it set on for a few hours before riding, it does fling tho. where in wolves are u craigk?
30-12-06, 08:04 PM | #15 | |
30-12-06, 08:27 PM | #16 |
ahh right by my place of work! we'll have to get a ride out in the summer.
30-12-06, 08:32 PM | #17 | |
30-12-06, 08:36 PM | #18 | |
Pete |
30-12-06, 08:40 PM | #19 |
yea i know but i dont like the look of a shi#y chain I'd rather change the chain at more regular intervals.
30-12-06, 10:20 PM | #20 |
Craig, it sounds like the drip tube is positioned OK. The black adjuster thing needs to be turned fully clockwise so the pointer is set to 'prime' (written on the reservoir rim together with the numbers 1 to 10 [I think], mine's under the seat too, its a bit hard to read without a torch). Then you need to force all the air locks out of the tubing by pushing oil through it using the oil bottle as a pump - push the nozzle of the bottle into the hole at the top of the rubber plug so there's an airtight fit and squeeze the bottle so the air locks move down the tubing, oil will only flow properly when all the air locks have gone. Then reset the adjuster to halfway again and run the engine, oil should drip freely if the vacuum pipe connection to the engine is OK. Mine's set on number 2, much less than halfway.
See the scottoiler website for where the vacuum tube is likely to be connected, it tells you all this stuff anyway, you can download the instruction manual. Hope this helps. |
rusty chain | AndyBrad | SV Talk, Tuning & Tweaking | 12 | 06-03-09 07:17 PM |
rusty chain is it scrap? | AndyBrad | SV Talk, Tuning & Tweaking | 18 | 30-12-08 11:16 AM |
rusty chain | Corf | SV Talk, Tuning & Tweaking | 1 | 29-12-08 01:32 PM |
Rusty chain? | gazman | SV Talk, Tuning & Tweaking | 35 | 05-02-08 11:52 AM |
Chain Rusty After Lay-Up: How to Clean? | Liam | SV Talk, Tuning & Tweaking | 8 | 01-04-05 01:49 PM |
