Old 15-08-14, 01:36 PM   #1
SV650S_DUB
Default Battery charger - connection / leads question
Afternoon all.
I have an Oxford Maximiser, but I no longer have the fused waterproof connector that allows me to hook it to my bikes battery with just a click-in /click-out fitting. This link shows the product I'm trying to describe: http://www.sportsbikeshop.co.uk/prod...connectors.jpg
Does anyone know if there are other brands, maybe Optimate, or even some generic products that can be used to link an Oxford Maximiser to a bike battery in a handy manner?
Thanks for any insight/tips.
Old 15-08-14, 01:59 PM   #2
TamSV
TamSV's Avatar
Default Re: Battery charger - connection / leads question
Yep, I always forget about them when selling a bike too.
They're industry standard connectors so you could probably make one up from your local Maplins or whatever, but the complete units are available on ebay etc cheap enough so it's hardly worth the trouble. For example, this one.
EDIT: Check the pictures carefully, Optimate have used 2 or 3 different connectors but I think this is the one you're after
Old 15-08-14, 02:23 PM   #3
aesmith
The connector is sold by model shops and suppliers under the name "Tamiya Connector" should be only a pound or so for the connector itself. I don't really see the need for a fuse.
Old 16-08-14, 06:58 AM   #4
rp16v
I have a fuse on my optimate it blew/overheated over night went out next morning and battery was compleatley drained poss due to negetive still being a solid connection
now looking at a new unit aparentley the halfords optimisers are prety good iv been given one just need a new adaptor for bike connection
Old 16-08-14, 08:03 AM   #5
You can't drain a battery with a single connection. The connector lead should most definitely be fused. Due the nature of the cable and its connection directly to the battery, any even slight damage to the cable is a real fire risk. As in any situation, the fuse should be as close the battery positive terminal as is possible.
Old 16-08-14, 12:58 PM   #6
rp16v
Ah ok may well just stick some new conector blocks on the optimate as the one at current is prety slack
Been thinking iv had a current draw for a while riped out the 10yo dataool imobiliser today to remove a possibility
Mystery connection on battery. goaty SV Talk, Tuning & Tweaking 4 14-07-10 03:05 PM
Battery earth connection. Neeja SV Talk, Tuning & Tweaking 13 28-12-09 11:32 PM
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
Help-Permanant battery connection-not underseat Dysparunia SV Talk, Tuning & Tweaking 6 20-02-07 12:20 PM
Battery Charger 600+ SV Talk, Tuning & Tweaking 15 22-01-07 03:07 PM
