Old 10-02-20, 11:30 PM   #21
Flybuster
Flybuster's Avatar
Default Re: Super heavy clutch pull (Snapped clutch cable)
Mine is a first gen curvy. I find the clutch quite heavy and actually painful after an hour or so. Less if town riding. I have an aftermarket lever but it looks like an oem, in size, but is carbon fibre look. I replaced the worm gear and cable with a Wemoto one and it fitted no problem. The clutch didn't really get lighter but the action and gear changes did get smoother.
I've tried re-routing and lubricating the cable, which probably helped long term but with no immediate difference.
Mind I'm no where near needing 2 hands to pull it in.
Flybuster is offline   Reply With Quote
Old 21-02-20, 02:00 PM   #22
mikerj
The grooves in the actuator mechanism wear, and even with new balls they don't work so well. The clutch on my fathers curvy was uncomfortably heavy despite a new cable and a cleaned, greased and correctly adjusted actuator, so he shelled out for a new actuator and it transformed the feel and weight of the clutch.
Clutch Cable Snapped! Goodfella SV Talk, Tuning & Tweaking 4 16-08-12 01:03 PM
Brown Trousers. (snapped clutch cable) alex.j SV Talk, Tuning & Tweaking 20 01-09-06 09:35 PM
Clutch Cable Snapped: MrMessy SV Talk, Tuning & Tweaking 2 16-01-06 09:18 AM
Clutch cable snapped on a 99 plate. Scoobs SV Talk, Tuning & Tweaking 13 13-05-05 10:28 AM
