Old 25-01-20, 11:38 AM   #1
Thaleshwar
Default Flushing coolant system
Hi, As I am considering coolant change in my SV650S K6, I studied online resources (google, YouTube.. all usual), everywhere it’s said or mentioned to flush coolant system by ‘pouring’ the distilled water, except Haynes service manual that I have for my model and year that reads (Page 1.30) QUOTE: Flush the system with clean ‘tap water’ by inserting a garden hose in the radiator filler neck:UNQUOTE to me flushing with garden hose does make sense as it exerts some pressure instead of pouring, but dilemma is cleaning with tap water vs distilled water, personally I feel it should not do any or much harm, am I right in following Haynes manual which is well respected? Kindly comment
Thaleshwar is offline   Reply With Quote
Old 25-01-20, 11:48 AM   #2
DJ123
DJ123's Avatar
Default Re: Flushing coolant system
IIRC the coolant system only holds a couple of litres, so even if you don't get all the tap water out it's not going to be a high volume that will cause issues later on.
You'll know how much is in there when you fill it all up and measure how much you have left in the jug of the total volume.
BMW F800ST
Old 25-01-20, 04:16 PM   #3
R1ffR4ff
R1ffR4ff's Avatar
See other reply/s and don't forget to follow the instructions to,"Burp" the system by running the engine up to the Thermostat opening and watching inside the Rad cap/level for bubbles( I use a Torch/Lamp) whilst sat on the bike and rocking it a little from side-to-side as per the Manual. You want NO air in the system!
Then let then engine cool and check the level and top-up as needed.
Old 25-01-20, 06:56 PM   #4
Thaleshwar
Thanks for pointing it out, I had learnt about it but had slipped out of my mind, and may have forgotten when doing the change, but this will remind me 👍
Old 25-01-20, 07:00 PM   #5
Thaleshwar
Thank you, you are right, I too had same thing in mind but was wanting to see the general opinion, as per the owner’s manual it takes 1700ml when doing coolant drain and change, so will keep an eye
Old 25-01-20, 07:27 PM   #6
R1ffR4ff
R1ffR4ff's Avatar
Be careful though because as soon as you are happy that you have all the air out switch the engine off as the coolant level will rise and at a certain temperature and overflow and can scald!
Old 25-01-20, 08:50 PM   #7
Thaleshwar
Thanks for the alert, I shall surely be careful 👍
Old 26-01-20, 01:43 AM   #8
unless your going to use some fancy coolant (not recommended) then no need to flush, just drain the old stuff out and fill with new stuff. use halfords red (pink) premix and you will be fine.
as far as i'm aware you can mix the blue and red coolant so a tiny little bit of old coolant left in the system is not going to make much odds, do you think a dealer would flush... fek no that takes time. its only those waterless coolants you need to be careful with and i would not recommend using them.
Old 26-01-20, 07:07 PM   #9
SV650rules
https://www.halfords.com/motoring/en...reeze-2-litres
Used this for years, get the premixed stuff, not widely known but 50/50 mix gives best antifreeze protection as above and below that ratio raises the freezing point.. it is not really the anti freeze glycol bit that wears out, it is the anti corrosion package..
https://www.halfords.com/motoring/en...reeze-5-litres
Works out cheaper per litre to buy 5 litre premixed but if you don't need it for anything else may be a waste..
2016 SV650 AL7
Old 26-01-20, 07:23 PM   #10
Thaleshwar
Many thanks for the advice; I bought the coolant this afternoon from Halfords, waiting for spark plugs to come through in post, as want to do spark plugs, air filter and coolant at the same time, oil and filter was done in 2018 and bike has not done 1000 miles since, so will change them next year.
Sealed System flushing advise. daveyrach Idle Banter 9 18-03-13 09:54 AM
Flushing the radiator DarrenSV650S SV Talk, Tuning & Tweaking 15 19-07-10 03:11 PM
Coolant system problem andrewsmith Bikes - Talk & Issues 17 19-06-10 10:15 PM
Coolant System Diagram Please. SV-net SV Talk, Tuning & Tweaking 3 17-03-08 12:07 AM
Akrapovic full system or yoshi full system ? ? ? hall13uk Exhausts 40 15-08-07 11:44 PM
