Old 22-06-17, 10:18 AM   #11
Blapper
Blapper's Avatar
Default Re: The Mysterious SV650 Tickling Noise
Something may be lost in the translation there...
Old 22-06-17, 12:45 PM   #12
think about why pointy owners adjust the TPS... same effect gets worse with worn chain sprockets. keeping the rear wheel in 'drive' by not shutting the throttle fully lessens the effect of backlash on the chain. this results in less noise from chain and a smoother ride.
Old 22-06-17, 04:06 PM   #13
Rogue_Shadow
Thanks again the suggestions
I'm Changing the oil filter tomorrow so will triple check the chain alignment & also soak the chain in the old oil.
If I can get this fixed It would be such a relief
The engine braking of the V-Twin is one of the things that like about the SV, so I'm definitely using all the gears prior to stopping. No block changes or coasting to the line here.
Old 29-06-17, 08:51 AM   #14
Hapo
...so it's not the fuel...???...(grin)
Old 29-06-17, 04:10 PM   #15
Rogue_Shadow
Nope nor is it the chain
Mysterious pipe! Lithium Bikes - Talk & Issues 1 18-01-16 11:13 AM
Mysterious ticking noise? Criggers SV Talk, Tuning & Tweaking 11 19-11-14 09:17 AM
Mysterious headlight problem Dunn-y Bikes - Talk & Issues 2 14-06-14 04:51 PM
Tickling and knifing people Fallout Idle Banter 29 06-11-13 03:48 PM
Mysterious paper sculptures HoL Idle Banter 2 10-01-12 09:40 PM
