Old 25-09-19, 08:33 PM   #1
JaxintheUK
Junior Member
Default Stator test with low voltage output
My battery has died due overcharging, so I've been doing test's to see what's wrong. I would say that my r/r is probably toast...it was a decent mosfet based one and only a year old, so there must be something else wrong with the system. Taking the r/r out of the equation I tested the ohms and all three wires were showing 0.5ohms. Next tested the continuity with ground on all 3 wires...no continuity, so that's fine. Tested the stator output and at 5000 revs it's showing 49 volts on each wire. The readings should be a minimum of 60v each. Does anyone know what would cause such a low output?
JaxintheUK is offline   Reply With Quote
Old 25-09-19, 09:18 PM   #2
johnnyrod
johnnyrod's Avatar
Default Re: Stator test with low voltage output
Are you doing it with the RR disconnected? I would have said 75V minimum but yeah 49 is low. Are you sure of the accuracy of your multimeter? Using it on AC mode not DC? Connecting it to a pair of wires from the stator, not to anything else? Sure you don't have any continuity to earth? If in doubt, double check all this stuff.
Old 25-09-19, 09:55 PM   #3
JaxintheUK
Junior Member
Yes, the r/r is disconnected. I used two different multimeters, so I know it works OK. Yes, it was on AC not dc. Definitely no continuity to earth. I've been reading a brilliant thread on here for testing everything, so I'll be checking everything again tomorrow.
Old 26-09-19, 07:19 AM   #4
Seeker
Seeker's Avatar
Broken/weak magnet on rotor?
Old 26-09-19, 09:54 AM   #5
JaxintheUK
Junior Member
That's what I'm thinking. It's always something...I've spent so much time fixing the bike that the summer has passed me by.
Old 26-09-19, 10:09 AM   #6
Seeker
Seeker's Avatar
I'd check the magnets for tightness and then I'd fit a new R/R (since your old one was overcharging) and see what your battery voltage is at idle and at 2k rpm.
Old 28-09-19, 12:13 PM   #7
JaxintheUK
Junior Member
I re-did the stator check, as I was doing it wrong...I was doing it to ground. At idle I have 30vac and 5000 revs its 100vac on all three pairs. Is this OK? I have a new r/r from a gixxer, is the voltage too high, or is it fine...I don't want to blow this one.
Old 28-09-19, 01:04 PM   #8
GeorgeRYoung
The manual just says more than 60V at 5000. My opinion is it should be fine.
65 CB160 (67-69), 69 350GTR (69-72), 72 R5, 73 RD350 (73-84), 82 XZ550 Vision (84-03), 01 Concours C10 (03-19), 89 EX250 (11-14), 00 SV650S (14-16), 03 SV650S (19-)
GeorgeRYoung is online now   Reply With Quote
Old 28-09-19, 07:50 PM   #9
JaxintheUK
Junior Member
It seems to work well, a nice 14.5v on the battery. It's made my day Then it started raining. lol
Old 29-09-19, 08:57 AM   #10
glang
good news but still hasnt answered why the original RR failed. You didnt jump/bump start the bike with a flat battery at some stage did you? In fact how do you know the battery died of overcharging? Also was the RR cooled as best as possible?
Electrical output 60-80 SV Talk, Tuning & Tweaking 11 21-03-19 10:00 AM
Can you help me read my stator test? (w/pictures) OliviaSF SV Talk, Tuning & Tweaking 101 11-09-16 07:32 PM
power output rude SV Talk, Tuning & Tweaking 23 13-01-09 06:57 PM
LED output? noob-saibot SV Talk, Tuning & Tweaking 7 25-11-08 10:13 PM
Checking Power output Morpheus SV Talk, Tuning & Tweaking 1 05-11-04 10:54 AM
