09-06-17, 09:46 PM | #11 |
Re: LED bulbs
not completely black'o'clock but not far off. please excuse the mess, its all going to the tip tomorrow.
dip dip_n.jpg high full_n.jpg pretty good light output |
09-06-17, 09:50 PM | #12 |
Re: LED bulbs
You need to do the standard bulb too! Also see what the output is like at distance
09-06-17, 09:53 PM | #13 |
Re: LED bulbs
i can tell you that the standard bulb on same wall was dull off white and about 1/3 of the brightness. i'm pretty impressed so far.
09-06-17, 10:42 PM | #14 |
Re: LED bulbs
Good info. Now you can find your way home when's the first bimble
used to be littleoldman but forgot password due to failing memory |
10-06-17, 05:48 AM | #15 |
Re: LED bulbs
Does the bulbs heat sink rse stick out past the headlight assembly oe cover.
Raisin cookies that look like chocolate chip cookies are the reason I have trust issues. |
10-06-17, 10:47 AM | #16 |
Re: LED bulbs
Hey Bibio, the problem as I see it and why I went for the Philips Extremes was that the LEDS use little power so the R/R runs hotter all the time...?
10-06-17, 12:19 PM | #17 | ||
Re: LED bulbs
top tip, you can fit these upside down by mistake. you want the two led's to form a pyramid upwards when installing them in the headlight. i think both bulbs are 60w rated not 'equivalent' rated. having said that i would guess that each led cob is 20w so dip uses 40w. add in the electronics+fan loss and its probably about the same. |
Thread Tools | |
HID Bulbs | TheRuffellator | For Sale - Other Bikes and General biking items | 3 | 11-05-13 05:45 PM |
45w / 12v bulbs ? | maclovin | SV Talk, Tuning & Tweaking | 1 | 10-08-08 10:39 PM |
Bulbs | Manguish | SV Talk, Tuning & Tweaking | 14 | 13-02-08 09:09 PM |
New bulbs!!!! | svrash | SV Talk, Tuning & Tweaking | 1 | 02-09-05 06:49 AM |
Bulbs | jonhunt | SV Talk, Tuning & Tweaking | 6 | 03-08-05 05:10 PM |
