22-10-21, 08:48 AM | #2481 |
Re: What have you tinkered with today?
Here's the solution? ...
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
22-10-21, 08:51 AM | #2482 |
True, but now these particular things are pretty old and tired - I'm a bit surprised at the prices being asked.
- K9 SV650S: Hel brake lines, carbon end can - SZR660: The project... - K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now) |
22-10-21, 09:39 AM | #2483 |
gsxr front ends are not the be all and end all. i have had a GSXR 600/750 K4-5 front end on my K7 for over a decade and its also been properly fettled with shim stack alterations etc.etc. the difference is about 10% better over a fettled standard front end but cost a whole lot more and the price difference is not worth it.
your better spending the money on a proper rear shock like a Nitron. then properly fettle the front end with springs for your weight, proper oil viscosity (this take a while to get right) and damper rod alterations. if you can outride a properly fettled standard front end then you should have a career in racing. the only difference is the brakes but i can tell you now that radial brakes on an SV is lethal. the SV brakes when they have been serviced correctly are good enough. |
22-10-21, 10:16 AM | #2484 | |
Cheers. I've already got a Nitron shock, and upgraded springs and oil in the forks. I did really like the feel of the GSXR front end I installed on my K5 waaay back in the day... ..and didn't find the brakes overkill at all. I certainly appreciate and accept the comment about being able to out-ride a sorted set of original forks, but then that could be said about any performance oriented upgrade -there's always someone who could go faster on what we think we've reached the limits on. To a large extent it's just down to personal preference (feel, and aesthetics).
22-10-21, 11:47 AM | #2485 |
On my K2 sv650 cafe racer. Fitted the head light in the fairing and removed my front indicator brackets which were stopping me getting the fairing low enough. also I have chopped the fairing support removing all of the part that mounts on the frame tube because it just wasn't going to work.
22-10-21, 12:59 PM | #2486 |
Does anyone know anything about the SV1000 I posted the pic of above? Apparently it was an official GSXR tribute model with GSXR front end and slightly upped power etc. I can't find any details about them anywhere though?
22-10-21, 01:20 PM | #2487 | |
If it's not a conversion, wouldn't it have been onto radial brake calipers by then?
22-10-21, 01:57 PM | #2488 |
From Suzukicycles.org
Suzuki 2006 2006 Suzuki year code: K6 2006 Suzuki SV1000SZ - Europe Model In the 20th anniversary year of the GSX-R series Suzuki release a special edition of the SV1000S. The SV1000SZ shares the same iconic colour as the GSX-R range and comes as standard with full fairing and a stylish looking all black frame, swingarm and wheels. Improved performance and quicker throttle response for an all round better performing machine. Suzuki SV1000S K4Suzuki SV1000SZ 2006 Overall Length: 2,085 mm (82.1 in) Overall Width: 745 mm (29.3 in) Overall Height: 1,170 mm (46.1 in) Seat Height: 800 mm (31.5 in) Wheelbase: 1,430 mm (56.3 in) Ground Clearance: 150 mm (5.9 in) Dry Weight: 187 kg (412 lbs) Engine type: Water-cooled 996 cc four-stroke 90° 8 valves V-twin, DOHC, TSCC. 123 hp (91.7 kW)/ 8,500 rpm, 102 Nm/ 7,000 rpm. TECHNICAL SPECIFICATIONS: Overall Length: 2,085 mm Overall Width: 745 mm Overall Height: 1,170 mm Wheelbase: 1,430 mm Ground Clearance: 150 mm Seat Height: 800 mm Dry Mass: 187 kg Fuel Capacity: 17 litres ENGINE: Engine Type: 90-degree 4-stroke V-twin, DOHC, liquid cooled, electronic fuel injected, 4 valves per cylinder Bore x Stroke: 98.0 x 66.0 mm Max Power: 125.1 PS Max Torque: 102 Nm @ 7,500rpm Piston Displacement: 996cc Compression Ratio: 11.6:1 Carburettor: Fuel injection 52 mm Lubrication: Wet sump ELECTRICAL SYSTEM: Ignition Type: Digital electronic Starter System: Electric TRANSMISSION: Clutch: Wet multi plate Transmission: 6-speed Drive System: Chain CHASSIS: Front Suspension: Conventional 46 mm telescopic. Fully adjustable Rear Suspension: Link type, coil spring, oil damped, fully adjustable Rake/Trail: 24.5 degrees / 99 mm Front Brake: 4-piston calipers, 310 mm dual discs Rear Brake: Singel-piston caliper, 220 mm disc Front Tyre: 120/70R15 Rear Tyre: 180/55ZR17 |
22-10-21, 02:47 PM | #2489 |
John T
You missed out the paint codes Gary
22-10-21, 03:20 PM | #2490 |
Damn! Knew there was something else!
