Old 05-05-12, 08:34 AM   #1
bert682
Default Curvy Chain Movement
Hi guys
Just cleaning my chain today and noticed some serious movement when the bike was running. Had it up on the paddock stand and the "jump" seems to be in the same place each time.
I can't get it to do the same when turning the wheel by hand so I guess its caused by the vibration from the engine?
Its a new chain (and sprockets) about 2 weeks ago. Video below shows the movement.
http://www.youtube.com/watch?v=RS9Aw...ature=youtu.be
Sorry for poor quality!
Rob
Old 05-05-12, 08:57 AM   #2
rictus01
rictus01's Avatar
Default Re: Curvy Chain Movement
from the video, it looks like a tight link, however as you say it's a new chain then it's more likely the rivet link was put on too tight and is causing the same effect, not a great deal you can do about it now, keep and eye on it and it well lubed, but it should ease up with use.
Cheers Mark.
Old 07-05-12, 05:50 PM   #3
bert682
I think I will just replace the master link. There only a few quid. Any recommendations on how to judge the tightness?
Rob
Sent from my Desire HD using Tapatalk 2
Old 07-05-12, 05:57 PM   #4
looks perfectly normal to me. mine slaps about something chronic till i give it a bit of rev.
Old 07-05-12, 05:59 PM   #5
bert682
I find the bike is jugging a bit though. I can feel it but the rev needle isn't jumping. I guess that means the chain?
Old 07-05-12, 06:00 PM   #6
if you turn the wheel by hand is there any tight spots to the chain e.g. kinked links.
Old 07-05-12, 06:02 PM   #7
bert682
Nope its perfectly smooth. I figured the jumping was coming from the vibration of the engine but that would handle enough to make me feel it chugging?
Old 07-05-12, 06:05 PM   #8
i've had surging before and it was too tight a chain. tight area was coming round and making the chain like a bowstring then it would go to the loose area so on and so on.
Old 07-05-12, 06:10 PM   #9
bert682
That's what I had before hence the new chain. It's definitely not as bad as before. I'm baffled. Ill try a new link and see what happens
Clutch pushrod movement? srobrien SV Talk, Tuning & Tweaking 5 29-02-12 12:56 PM
Naked curvy chain guard and chain Squatepantz Stuff Wanted 0 10-05-11 07:41 PM
EMDR (Eye Movement Desensitisation and Reprocessing) Rai86 Idle Banter 3 15-05-10 12:23 AM
Throttle movement question when fitting r6 twistgrip Loser SV Talk, Tuning & Tweaking 6 23-07-09 02:17 PM
disc movement Dave20046 SV Talk, Tuning & Tweaking 23 30-03-09 05:54 PM
