28-04-09, 04:34 PM | #1 |
Is a vernier gauge a good (easy) way to check real wheel alignment? (NOT SV)
28-04-09, 04:49 PM | #2 |
Re: Is a vernier gauge a good (easy) way to check real wheel alignment? (NOT SV)
I doubt it.
That said, line the wheels up with string/straight edges and then measure - even if they're not the same at least you'll know what the difference needs to be for the wheel to be straight.
28-04-09, 11:15 PM | #3 |
Only if the swing arms been built dead accurate. And sometimes they're not, apparently.
Silver Curvy - Carbon Can..........Err, that's it - Gone. Replaced by Black SV1000N, fender extender ...........Err, that's it. |
28-04-09, 11:24 PM | #4 | |
Tried and tested method. Using vernier there risks all the same errors as using the marks if not a few more.
28-04-09, 11:30 PM | #5 |
OP, in a word, no. The measurement you are taking is far too small to give a proper indication of wheel alignment and would rely on the swingarm being bob on in its pivots to the frame which they hardly ever are.
I use 2 lengths of aluminium extrusion clamped either side of the rear wheel so they are parallel then measure the 4 gaps to the tyre at the front and adjust until they are all the same. |
Wheel alignment problem. | smrgup | SV Talk, Tuning & Tweaking | 9 | 08-05-09 01:49 PM |
Wheel alignment question | Grant66 | SV Talk, Tuning & Tweaking | 17 | 26-02-09 07:20 AM |
Wheel alignment, again | muffles | SV Talk, Tuning & Tweaking | 4 | 29-07-07 12:26 AM |
wheel alignment for k2 naked | ejohnh | SV Talk, Tuning & Tweaking | 7 | 01-12-06 09:39 PM |
Wheel alignment | Ratty | SV Talk, Tuning & Tweaking | 9 | 11-07-06 07:57 AM |
