13-05-07, 07:11 PM | #1 |
Making your own bike camera setup ala' Gp style!
Sitting down thinking how this could be done ....
Using webcam's Usb hardrives or some other recording device Shock / bump protection so the recording doesn't jump Modify the webcams wiring to plug into the recording device as a fixed camera making it front/back switchable during rideout's or position switchable if you fancy more than one camera! Any thoughts?
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ), drop it & fix it again! K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
13-05-07, 08:16 PM | #2 |
Re: Making your own bike camera setup ala' Gp style!
Webcams dont output in PAL so a non starter really.
You could use a bullet cam and a Archos hard drive recorder, I have done that sucessfully. However, now that video camcorders are so ridiculously cheap, I'd probably just buy one of them and a roll of duck tape. |
13-05-07, 11:15 PM | #3 |
Ram mounts are a good way to mount a single camera to the bar
15-05-07, 08:45 PM | #4 |
Or just buy a ATC2000 for £100, small, light, comes with fitting kits, uses AA batteries and an SD card
15-05-07, 10:05 PM | #5 |
Rob, I was looking at the ATC - have you used one? any good?
SV650SK3 - GSXR600K2 - GSXR750K6 - ZX636RC1H - HD Sportster 1200 - CBR600F 2012 - GSXR1000K7 - Triumph Bonneville T100 2019 - Aprilia Tuono 660 |
15-05-07, 10:26 PM | #6 |
No but i've seen a fair bit of footage and its certainly good enough for on-board stuff
16-05-07, 08:51 AM | #7 |
www.dogcamsport.co.uk & have a hunt around on their site.
I'm thinking of getting either their 420 or 480 bullet camera. This comes with all the needed gubbins. They do a kit with a mobibox recorder (also doubles as an FM radio & MP3 player). 512Mb storage built in, and takes up to 4GB SD cards. Powered by Li-Ion battery & camera powered by 8xAA pack (supplied). Sucker mount (for helmet or bike use) and static mount supplied. Cost? Approx £190 for the 420 kit. |
16-05-07, 05:56 PM | #8 |
when i worked for jessops i sorted out my DAS instructer for this exact purpose. . . . got a mint DAS reduction I might add.
but the best thing in my opinion for this is get a cheap Mini DV Camcorder With (DV in) you can ger cheap CCD cameras and a spliter, attach them all together and walla! you should get the whole set up for about £250 there is plent of cable too, my mate used to secure the actual camcorder in his backseat thats one idea anyhow |
16-05-07, 06:41 PM | #9 | |
17-05-07, 12:53 PM | #10 |
http://www.iwantoneofthose.com/gadge...era/index.html probably a similar one to the camera the others have been mentioning. wack it on record, play it when you get home, and do some editing on the comp so you can have some heavy rock playing over the top et viola!!! think i might just have to get one.
pair it with one of these http://www.iwantoneofthose.com/gadge...ear/index.html and you can pretend to be riding your bike in the lounge!! just dont wear them when on the bike! Last edited by riktherider; 17-05-07 at 12:55 PM. |
Bike camera or camera mount! | chompy | Stuff Wanted | 3 | 16-03-09 04:16 PM |
Bike Boots.....in the making???? | 454697819 | Bikes - Talk & Issues | 14 | 10-04-07 07:32 AM |
Pointy K3> twin can setup for 650, does 1000 setup fit? | aposegil | Stuff Wanted | 3 | 26-10-06 03:41 PM |
Should my bike be making this noise? | dmracing | SV Talk, Tuning & Tweaking | 6 | 13-03-06 03:57 PM |
Bike not making top speed. | sprocket | SV Talk, Tuning & Tweaking | 5 | 03-09-05 07:54 PM |
