Old 22-06-18, 04:27 PM   #1
Default Pointy Rear Linkage Rate
i have always wondered about the true linkage rate of the pointy so while i have the spring off the Nitron i measured the total shaft length before it hit the bumper and is 35mm.
i then put the shock back in the bike and raised the rear till it hit the bumper. the measurements were 485 total length and 405 compressed which is 80mm. so 80/35 gives 2.28 so lets round it up for loose bolts and say 2.25mm
so we all now know the (good enough) linkage rate is 1-2.25mm which means for every 1mm the shock shaft travels the rear wheel will travel 2.25mm.
Old 22-06-18, 04:34 PM   #2
Talking Heads
Default Re: Pointy Rear Linkage Rate
Well, you've ruined the wonder of what the linkage rate is, you'll have to find something else to wonder about now.
Talking Heads is offline   Reply With Quote
Rear shock linkage and rear caliper garynortheast SV Talk, Tuning & Tweaking 15 21-07-22 09:02 PM
K3> linear rear linkage. lawson17 For Sale - SV's and SV related items 0 01-05-15 06:07 PM
WTD - Pointy LH Rear Set & Gear Linkage Markos_46 Stuff Wanted 1 23-12-14 12:16 PM
Rear suspension linkage wanted theboatman Stuff Wanted 12 21-05-13 10:02 PM
Rear linkage bearings yorkie_chris SV Talk, Tuning & Tweaking 5 16-02-10 11:14 PM
