Right, firstly this isn't on an SV, hence the post in here. its a '97 ZX7R.
Now I've done a few sproket changes in my time and NEVER have I encountered one this tight. I have a 2 foot breaker bar on it with a hefty chunk of wood through the back wheel / swing arm to prevent the sproket turning. Already snapped one piece of 2" x 2" timber! I've left it covered in WD40 for the night (as my back is now killing me). It won't budge at all. Should I try a longer breaker bar or would an impact driver be better? I am just worried about damaging the nut if I put too much force on it. Am i missing something, like do these nuts undo in the oposite direction to normal??? Come to my rescue the org. ![]() ![]() ![]() |
You haven't got me and my gut sitting on it to hold it down
Assuming that you're doing it right, that is; turning the right way and have removed whatever locking device is fitted, then I'd stop struggling with it and take it to someone with the right equipment, by which I mean a compressor and and a rattle gun to buzz it off with.
I got the front sprocket off once, only to find when I thought I'd put it back on it was not tight enough etc. I'd always take it to someone with a compressor as Sid mentions, you can never get it tight enough (oh er)
SV650SK3 - GSXR600K2 - GSXR750K6 - ZX636RC1H - HD Sportster 1200 - CBR600F 2012 - GSXR1000K7 - Triumph Bonneville T100 2019 - Aprilia Tuono 660 |
#5 | |
Looks like I might have to ask around at work to see if anyone has access to a rattle gun. i was hoping it wouldn't come to that. |
You could try PlusGas spray instead of WD as this really helps to un-seize stuff - maybe try tightening it a bit to crack it then it might undo...?
D |
Best bet is an impact driver with the right size socket. I have a portable one but your a bit too far away mate sorry
Front fairing removal on K3? | AJR | SV Talk, Tuning & Tweaking | 8 | 13-01-12 11:58 PM |
front wheel removal tool? | w1ll15 | SV Talk, Tuning & Tweaking | 11 | 20-09-10 02:35 PM |
Front muguard removal. | Tomtoms | Bikes - Talk & Issues | 8 | 19-01-09 12:58 PM |
Front Sprocket Removal Help | kashby | SV Talk, Tuning & Tweaking | 41 | 20-02-08 09:39 PM |
Chain & Sprocket advice required. | Jester666 | SV Talk, Tuning & Tweaking | 15 | 15-08-07 01:15 PM |
