08-09-11, 08:08 PM | #1 |
Bent handlebar
After my left side drop ive been freaking out round corners, now partly its just me getting back on the bike, but the bike aint handling right. The forks are fine ive checked and re-checked them, but ive noticed that the wheel seems to go off to the right once i go out a mile down the road.
I think its now obvious that the left handlebar (clutch lever side?) has bent itself in with the weight of the bike dropping on it (its hard to notice but ive read this is sometimes hard to see). And my arms natural tendency to keep the bike straight isnt working. In effect my left arm is pushing it away more to the right when i get to that relaxed mode, so with arms not being equally straight then my shoulders arent straight then my body weight isnt balanced etc... Also this will be affecting the way i take corners as i will be over-exerting one way and under-exerting the other. Pics to follow as i took some showing the steering at full lock either side and comparison with how close the handlebars get to the tank. Ive done a bit of reading and im wary straightening them as the are only alum-cast Ive noticed the following part but it says right bar (but it looks like a left to me) http://www.svspares.com/items/227-1_...t-hand-650.htm Looking obvious but im not sure if they are supposed to be equi-distant... If some kind soul would check on theirs i would be grateful
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ), drop it & fix it again! K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. Last edited by muzikill; 08-09-11 at 08:24 PM. |
08-09-11, 08:28 PM | #2 |
Re: Bent handlebar
Its not bent, it needs repositioning thats all.
08-09-11, 08:34 PM | #3 |
Re: Bent handlebar
08-09-11, 08:57 PM | #4 |
Re: Bent handlebar
can this be done? the bars have a positioning pin that locates the bar under the yoke that stops you from doing this.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ), drop it & fix it again! K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
08-09-11, 09:06 PM | #5 |
Re: Bent handlebar
It was done on mine mate. I pointed it out to YC and he did it there and then. My left hand bar came closer tomy tank on left lock than the right and he just slackened it off, moved it round and retightened
08-09-11, 09:41 PM | #6 |
Re: Bent handlebar
Hey pal if you need a new one i got a pair sat in the garage doing naff all.
Joe |
08-09-11, 09:47 PM | #7 |
Re: Bent handlebar
take off the grips and check the straightness of the bar with a ruler/straight edge. Check that the upright of the clip on (from the fork leg upwards) for straightness. Also measure the distance between the end of the bar and centre of the pre damp. Compare both sides and that should give you an indication as to if it is bent or not.
08-09-11, 09:47 PM | #8 |
Re: Bent handlebar
yours a curvy? pointy has a location pin on the handlebar.
Im interested to know how he measured the distance to get it the same as the other side
08-09-11, 09:47 PM | #9 |
Re: Bent handlebar
09-09-11, 06:36 AM | #10 |
Re: Bent handlebar
We looked at the gap on right lock and made the gap the same on left lock. Didnt measure anything, just by eye.
Bent exhaust | lukewalton | SV Talk, Tuning & Tweaking | 5 | 04-01-08 02:04 PM |
Bent exhaust | lukewalton | SV Talk, Tuning & Tweaking | 0 | 04-01-08 01:39 AM |
Bent rim! | phil24_7 | Bikes - Talk & Issues | 18 | 01-11-07 02:51 PM |
Bent fairing | Bayside GTR | SV Talk, Tuning & Tweaking | 6 | 01-11-07 12:25 PM |
Bent Forks... how much is too much? | WhiteRabbit | SV Talk, Tuning & Tweaking | 1 | 13-11-04 01:09 AM |
