Old 17-11-10, 08:06 PM   #1
Nickgibbs
Cool Oxford grips controller problems
Hey all,
Any one had problems with the new conroller on Oxford heated grips, mine keeps flashing blue light 5 times then switches off?
chaged to new battery and wired direct to battery but still does intermitent
???? any ideas ???
Old 17-11-10, 09:17 PM   #2
Stuuk1
Stuuk1's Avatar
Default Re: oxfor grips controller problems
Did you waterproof the plug joint in the cable from the control box (by the battery) and the unit on your dash?
E.g. wrap it in electrical tape...
RIP Reeder 20/07/1988 - 21/03/2012
Stuuk1 is offline   Reply With Quote
Old 17-11-10, 09:45 PM   #3
Nickgibbs
Yes i did with insulation tape, on the plugs
Will see how it is friday on my next ride, cleaned all connectors and someone said the sv650 needs to run abit so only switch on when i am motoring along..
Old 17-11-10, 10:23 PM   #4
Check your charging voltage with a multimeter, if this is fine then grip control is at fault
Old 17-11-10, 10:45 PM   #5
DarranID
Thanks for posting this, I've had Oxford grips on my k6 for a year now and have a similar issue. According to the instructions, flashing blue light means not enough power - A safety feature to ensure it only runs off the engine not the battery. I find that they'll work once I give a bit of rev while holding the on button. If I'm sitting at the lights for a while they tend to switch off...
Old 17-11-10, 11:46 PM   #6
Nickgibbs
Darran, do you have the new controller box?
As you say you hold down the on button
Old 18-11-10, 07:15 AM   #7
2hys
is your battery in good nick?
if iirc if it dropes below 11.5v then it cuts out/wont switch on
if thats all ok then your controllers probally had it! mine done it when there were new
and the shop replaced it, all fine for two winters but this year i went to test them and
they had packed up completly, ive just hard wired them through the hazard switch,
Old 18-11-10, 10:27 PM   #8
DarranID
This is the set I have:
http://shop.sydneycitymotorcycles.co.../1340059-1.jpg
I think there is a small v6 on the bottom right of the control box.
As I said, they generally work ok but switch of after any length of time at low revs
Old 21-11-10, 10:33 PM   #9
Nickgibbs
Default Re: Oxford grips controller problems
Thanks all who gave advice on this, i have tested again today with not touching the on switch until i have done at least two miles. The blue light blinks 5 times then comes on after 30 seconds. worked like this all day today so fingers crossed but i will give Oxford a call tomorrow to check if this is normal.
Cheers....
Making my own heated grips controller Alpinestarhero SV Talk, Tuning & Tweaking 125 09-11-12 08:36 AM
Oxford Grips Problems with new controller Nickgibbs Bikes - Talk & Issues 2 17-11-10 07:57 PM
Reg/Rec, Oxford Grip Controller boot SV Talk, Tuning & Tweaking 9 18-11-09 08:11 PM
New oxford heated grips controller Alpinestarhero SV Talk, Tuning & Tweaking 21 30-09-08 03:00 PM
Mounting the Oxford Controller Mark_h SV Talk, Tuning & Tweaking 12 06-02-08 05:51 PM
