Old 23-02-17, 01:09 AM   #41
Default Re: Anyonen had a stuck oil filter recently?
Originally Posted by synXero View Post
Just whilst I'm here: Champion oil filter OK? Valvolene 10w30 fully synth? Bike is a London commuter but sees redline now and then
buy an OEM (Suzuki) filter. cheep filters are just that full full cheep materials and carp bypass valves. if the bypass valve opens too soon then the filter is not filtering.
as long as its bike oil and 10w40 then its good to go. cheep oil change more often e.g. halfords semi synth bike oil i would say 3k miles but fully synth 3.5-4k miles. dont go beyond 4k miles on any oil. the oil might be ok but the cleaning/clumping agents are gone and its these that keep the internals clean by clumping all the nasty stuff together so it gets caught in the filter media easier. change the filter every oil change especially if your doing short journeys.
Old 23-02-17, 03:47 AM   #42
synXero
Much appreciated. Doesn't say much about PO that it came supplied with the wrong oil grade... I bet this bike has some lovely surprises in store for me!!
Old 23-02-17, 10:59 AM   #43
Blapper
Blapper's Avatar
Be positive mate - my bike had the 'wrong grade' oil in it (Top Motul product) because the PO thought if it says 'meets or exceeds all existing specifications' it must be better. He did right by everything else though, so all's well. May be the same for you.
Old 23-02-17, 11:51 AM   #44
tom_e
While 10w30 may not be the defacto choice it's still fine for the temperature ranges seen in the UK according to the service manual so I wouldn't even give it a second thought.
tom_e is offline   Reply With Quote
Old 23-02-17, 12:19 PM   #45
Craig380
Especially with the UK bikes having an oil cooler, which is useful for about 2 weeks per year over here ....
Old 24-02-17, 12:25 PM   #46
aesmith
Interesting as most people say not to use fully synthetic except where the manufacturer specifies. (Although my SV has had the odd top-up with fully synth if that's all I've had to hand).
I've been using this stuff, from an oil and lubricants specialist and it meets all the same standards at £18.99 for 5L. It's a supplier I've used for more specialist lubricants which is why I use them in particular. http://www.ebay.co.uk/itm/121591448043
Old 24-02-17, 12:41 PM   #47
R1ffR4ff
R1ffR4ff's Avatar
I was looking a that oil myself
I went with the Motul kit I posted just for convenience.
A local older rider(Older than me! )
Runs a 1,000 cc Honda.I can't remember if it's a Fireblade or a CBR but he buys 25 ltr drums of semi synthetic 10w40 diesel engine oil from a local supplier and is a bit OTT on oil changes around every 1000/1500 miles but one of his Hondas had,at the last time I met him,198,000 miles on the original engine and still sounds sweet.
I hope I see him again this summer for an update
Old 24-02-17, 12:47 PM   #48
aesmith
Probably not to be recommended, but when I lived on a farm a while ago we used some stuff called "Agri Castrol" for everything. We had a 205L drum in the workshop with a hand pump to dispense. It went into .. tractor engines, tractor rear end, other hydraulics, chainsaw 2 stoke mix, chainsaw bar oil, our car engine, and of course my motorcycle.
Old 24-02-17, 12:54 PM   #49
Blapper
Blapper's Avatar
Probably not to be recommended, etc
A long way better than nothing at all, but also worse than the right grade/JASO/API.
Old 24-02-17, 01:19 PM   #50
R1ffR4ff
R1ffR4ff's Avatar
Here's a damn good read.I've read a lot on engine oils over the years,
http://www.nightrider.com/biketech/oiltest1.htm
Haven't been on here recently. Felix_ Photos 10 03-08-12 09:39 PM
What U-turns have you done recently? Nobbylad Idle Banter 13 27-10-11 07:37 PM
Done anything silly recently? Jayneflakes Photos 16 18-09-11 07:49 AM
Hobby - have you taken one up recently? Miss Alpinestarhero Idle Banter 55 09-07-09 05:24 PM
Not been recently. REEVESIE Soho Massive 2 02-12-05 12:05 AM
